check engine light and red triangle
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Juan, Jul 10, 2012.
  1. Juan
    Juan New Member
    Check engine light, red triangle with exclamation, and on the monitor a red box with a picture of a car with exclamation came on after changing the rear brakes. I checked the water flow control valve and water pump. Don't know what else to check.
  2. El Dobro
    El Dobro A Member
    6,985
    3,218
    I'm sure someone will correct me if I'm wrong, but changing the rear brakes on GenII Prii sets an ABS code that has to be cleared by the dealer or someone with access to diagnostics.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ** Mod Note - moved to correct forum **
  4. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    360
    Was the safety interlock removed? If so did you slide the lever up after flipping it back?
    dave77 likes this.
