Check Engine Light Just Came On
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TSW, Nov 23, 2016.
  1. TSW
    TSW New Member
    US
    I have a 2013 Prius C4 and my Check Engine light just came on. It's Thanksgiving Eve and I'm supposed to pick somebody up at the Wilkes Barre, PA airport Friday morning. So nobody's open to check it out. Any ideas? Should I risk the 3 hour round trip drive before getting this checked out?
  2. Mendel Leisk
    38,735
    My hunch, no. Play it safe, they can take a cab.
    Might be overkill but who knows.
    TSW likes this.
  3. TSW
    TSW New Member
    US
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    You might try cycling the car on and off a few times, perhaps disconnecting and then reconnecting the 12V battery to "reset" the cars computer to see if the CEL goes away. If it doesn't, or if it reappears then I agree with Mendel - better safe than sorry.
    My understanding is that the CEL can be triggered by some pretty trivial things - for example, failure to properly screw on the gas filler cap. So I think it's worth at least an attempt at a resetting it. But I'm not an expert on it, so it might be wise to Google >"prius c" cel reset< to read up on it a bit.
    TSW likes this.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The idiot light can indicate anything from a BS problem like a loose gas cap up to catastrophic failure. Without reading the codes there is no way of knowing. I would not disconnect the battery just to clear the code.
    I bought a ScanGauge for the additional instrumentation and the ability to read and clear codes.
    TSW likes this.
  6. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    The Prius is completely safe to drive with a check engine light that is not flashing.
    If the check engine light is flashing it indicates a misfire condition that can damage the catalytic converter and in this case the Prius should not be driven.
    TSW and Mendel Leisk like this.
  7. Mendel Leisk
    38,735
    Didn't know that.
    TSW likes this.
  8. TSW
    TSW New Member
    US
    All my fluid levels are good and the gas cap was securely tight. I've also intermittently seen the air bag error light come on, but I don't know whether there's any connection. Seems as if I was able to do a CEL reset, it should come back on if there's still a problem. Agree?
  9. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
    Yes, read the code if the check engine light returns.
    Unlike the hybrid error codes that need to be read with a computer loaded with the techstream software, check engine lights can be read with inexpensive OBDII readers.
    My local Walmart sells an inexpensive OBDII reader / reset tool for just under $20
    icyrius, Mendel Leisk and TSW like this.
  10. Mendel Leisk
    38,735
    ^ I think this daschshund knows his stuff!
    TSW likes this.
  11. TSW
    TSW New Member
    US
    It's a solid light, not blinking. I'll have to buy one of those code readers, but I'll probably take it to Advanced Auto when I return from Wilkes Barre Airport. I found a different car to drive.
  12. AtkinsonCycle
    AtkinsonCycle Junior Member
    31
    Pennsylvania
    Hello, TSW. I also have a 2013 C (mine's a Two), but no CEL. I live in south central PA. Not sure where you are at, but if you are close to me, I do have a working Techstream set up which would provide more detail as to the nature of the CEL on your car. Again, I am not sure if our locations are convenient, but I thought I would offer. Good luck. Hopefully, it's something easy and inexpensive.
