Check engine light -- now you see it, now you don't
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Vic Doucette, Jun 1, 2017.
  1. Vic Doucette
    Vic Doucette Junior Member
    Michigan
    2010 Prius III, 101K miles. It sat for three weeks without being driven, though I started the engine and let it run for a few minutes three or four times.
    I took it out for a drive this afternoon and noticed the check engine light was on. The guy at the auto parts store pulled a code of P0301, Cylinder 1 misfire detected. The suggested remedy was a new spark plug. That's not surprising, but I didn't think that was due until 120,000 miles. The car seemed to be running normally, without any problems that I could notice.
    I called my mechanic, and he can't get me in until sometime next week. He suggested that I drive as little as possible until then, claiming I might damage a coil. I'm good with that, but I was miles from home and in the middle of doing things that had to be done, so I kept driving and running my errands.
    Later that day, I saw that the light was off.
    Did I magically cure the problem? Do I still need to get to the garage ASAP? Will I win the Powerball this weekend? What gives?
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    you're good to go
  3. Mendel Leisk
    38,727
    Check the battery?
    49,492
    gas cap?
  5. Vic Doucette
    Michigan
    Gas cap was the first thing I checked. Haven't checked battery.
