Check engine light, P0101 and P0172 codes. Safe to drive?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by srellim234, Jul 13, 2022.
  1. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    The check engine light came on and Torque Pro is showing codes of PO101 (Mass or Volume Air Flow Circuit Range) and PO172 (System too rich). Is the car okay to drive to the tire shop (picked up a nail in the left rear) and then the 50 miles to the dealer to get it fixed or should it be towed?
    Don't know if it's a contributing factor to whatever the codes are referencing but the weather has been over 110*F out here all month.
  2. JC91006
    16,679
    8,521
    Yes the car is safe to drive.
    The MAF sensor maybe dirty (or need replacement). They don't fail often so check your air filter, see if it's dirty and needs replacement also (since you have to remove filter to see the MAF sensor)
    There is a MAF sensor cleaner you can buy for less than $10, just spray it on there (after you take it off the car). If cleaning it doesn't get rid of the check engine light, then go buy another used part from Ebay or something (original part would be best). You may be able to get them at junk yards too (since Gen 2 cars are becoming disposable)
    srellim234 likes this.
  3. JC91006
    16,679
    8,521
  4. PriusCamper
    PriusCamper Senior Member
    12,096
    4,902
    Pacific Northwest, USA
    Don't take the car to the dealer... It's way too old for that. Toyota dealers are warranty specialists. They're 100% guaranteed to try to replace the most expensive parts even if it's not necessary because that's how they get the most benefits for their business when they do warranty work. You need to find an honest mechanic who will fix your problem for lowest cost, not the highest.
  5. srellim234
    1,201
    1,694
    Laughlin, Nevada
    Thanks for the advice. The air filter is relatively new but out here with the dust storms ia new one can get dirty in a hurry. I'll try your tips and see if that works. If not, I do have a local mechanic who has done a few things but has very little experience with Gen II Prii.
  6. srellim234
    1,201
    1,694
    Laughlin, Nevada
    BTW, Long time no talk. was your business able to survive the slowdown from the pandemic? How's your wife these days?
    #6 srellim234, Jul 13, 2022
  7. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
  8. srellim234
    1,201
    1,694
    Laughlin, Nevada
    It's back again, six months after the dealer fixed it and cleaned the throttle body.
  9. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    What did the dealer do last time; just cleaned up the MAF, throttle body, and butterfly valve?
    Was there anything else listed on the invoice?
  10. mr_guy_mann
    mr_guy_mann Senior Member
    3,978
    1,923
    NJ-USA
    If you had the problem happen again, did the dealer ever really "fix it" in the first place?
    What do you have to scan the car, and are you interested or capable of diagnosing this yourself?
  11. srellim234
    1,201
    1,694
    Laughlin, Nevada
    They couldn't find the specific problem in January so they did exactly that.
    I decided to take it there yesterday anyway. A quick clean of the MAF didn't help. Tests showed the long term trim (whatever that is, I'm not a mechanic) at 30%. They swapped in a used MAF from another car and everything checked out fine, meaning the original MAF wasn't getting something bad fed into it; the problem was the MAF itself. They installed a new MAF. According to the invoice, "Replaced sensor, cleared codes and retested. Long term fuel trim now at 10% and all input and output readings are normal."
    I know it was expensive going through the dealer but I'm not a DIY guy and there aren't any mechanics around here that are comfortable working on a Prius. Even a medical courier service was using Prii and running their cars down to the dealer in Lake Havasu. The courier finally changed vehicles since there are mechanics, a Ford and a Buick/Chevy/GM dealer here locally for ICE cars. This area has a lot of catching up to do with regards to hybrids and electrics.
  12. dolj
    dolj Senior Member
    8,244
    4,199
    Wellington, New Zealand
    The funny thing is that that part of the engine is no different from a Corolla, Yaris, or Camry. In fact, probably not a lot different from a myriad of mainstream cars.
    srellim234 and PriusCamper like this.
  13. DigDoug
    DigDoug Junior Member
    64
    17
    Pennsylvania
    I have the same recurring problem, happened around a month ago was replaced with a new air filter and now I have it again.
  14. mr_guy_mann
    3,978
    1,923
    NJ-USA
    What codes do you have? Did you do anything besides replacing the air filter? Have you tried properly cleaning the MAF sensor and throttle body?
    DigDoug likes this.
  15. DigDoug
    64
    17
    Pennsylvania
    I replaced the MAF and air filter. PO101 is the only code I am getting. This was the first code since the replacement battery. I kept the original MAF and may just purchase some cleaner, clean and reinstall it.
  16. DigDoug
    64
    17
    Pennsylvania
    Things just get curiouser and curiouser, had the CEL light on when I went to work today and again when I returned home, just about a half an hour ago I moved the car and no code. I am flummoxed here.
  17. JC91006
    16,679
    8,521
    A bad catalytic converter would do that
