Check engine light (PO301... Misfire in Cylinder 1)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by worldaven, Sep 5, 2016.
  1. worldaven
    worldaven Member
    113
    16
    Hello,
    The check engine light went on this morning. Went to a local service station to get the code checked. (Toyota dealer was closed because of Labor Day.) They pulled this code.
    How bad is this?
    I'm 350 miles away from home, can I drive it and let my hometown mechanic repair it, or should I have it taken care of before I drive back tomorrow?
    What's a reasonable price to fix this?
    Anything else I should know about this issue?
    Thank you in advanced...
    M
  2. JC91006
    16,674
    8,519
    What year is your car? How many miles on it?
    How badly is it misfiring? The most common problems with misfiring is a bad spark plug or a bad coil.
  3. worldaven
    worldaven Member
    113
    16
    2010. 65300 miles. Not misfiring badly. If the light wasn't on, I probably would not have noticed it.
  4. JC91006
    16,674
    8,519
    Then it probably is safe to drive home, just remember you won't have as much power as normal.
    It might be an egr issue, which has an extended warranty
  5. 2004priusgal
    2004priusgal Junior Member
    76
    new jersey
    Upgrade
    Did you confirm what problem was? i have similar issue...
