check engine light reset
Discussion in 'Prius v Main Forum' started by hj630, May 24, 2017.
  1. hj630
    hj630 Junior Member
    26
    Naperivlle
    My wife didnt tighten the fuel cap so the check engine light came on. Now that she tightened it, the light is still on, will it go away after a while or I have to do something to reset it? Thanks
    49,492
    it should go away after being driven a few times. or an auto parts store can reset it for free with their scanner.
    Raytheeagle likes this.
  3. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Three driving cycles typically resets codes (and the CEL)
  4. lovenycpizza
    lovenycpizza Junior Member
    22
    24
    florida
    2014 Prius v wagon
    Remove negative terminal wire on 12v battery for 10seconds. Worked for me after diagnosis from auto parts store for code po441/455.
    Auto parts stores will only do check not reset.
  5. travisc220
    travisc220 New Member
    Grove, OK
    I got the 441/455 light from the store scan, bought the gas cap, went back and had them delete the codes. Light still on after 3+ drive cycles.
  6. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
  7. ChapmanF
    15,617
    There can be other causes for those codes, so it's possible the light's still on because no one's diagnosed and fixed the problem yet.
    Brian1954 likes this.
  8. ColoradoBoo
    ColoradoBoo Senior Member
    964
    631
    Monument, Colorado USA
    Topping off the gas when filling up can, also, pop a code if some gas gets into the onboard vapor recovery system. (There's a tube up near the top of the gas fill and if the person refueling continues to put gas in after the auto-shutoff they can let gas get in there...very bad and expensive issue to get fixed.)
    I see folks all the time at gas stations way overfilling their cars....just let it fill automatically and when it stops, that's it. (Replacing the charcoal cannister is around $400 plus labor time.)
    Air_Boss likes this.
  9. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Plus it can thow your gas gauge off
    Air_Boss and ColoradoBoo like this.
  10. John March
    John March Junior Member
    26
    Winston Salem NC
    2014 Prius v wagon
    I have an iphone 11 and purchased a nexas OBD code reader on amazon. I believe the cost was pretty reasonable. It allowed me to have functionality with the dr. prius app and another app i use for diagnostics called car scanner. It worked great when I forgot to hook up the hose to the intake manifold and the car threw a bunch of codes. I.e. works great for forgetfulness and diagnosing real problems
  11. travisc220
    Grove, OK
    I have replaced the fuel cap and purge valve and CEL is still on after probably 7-9 drive cycles and probably 150+ miles. The codes were "permanent" they said (where the scanner can't reset them) designed so people couldn't pass emissions tests or inspection simply by clearing codes beforehand. Only way they clear is by driving pattern
  12. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    Read posts 4 and 7.
