Check engine light & water sensor # 16670-21010
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by aliciadeso, Jul 17, 2011.
  1. aliciadeso
    aliciadeso New Member
    I have a 2005. My check engine light has been on since before the last recall, over a year ago. The recall was supposed to fix it, but it has not. I've taken the car in probably 6 times asking them to check it, but they never found anything until yesterday. They are telling me it's the water sensor # 16670-21010, and want $529 to replace it.
    Anyone?
  2. Patrick Wong
    18,200
    6,474
    It is hard to comment on your situation without knowing the DTC logged by your car. If that was provided to you, please post.
    However, the particular part that you listed, which is the valve for the engine coolant heat recovery system, is a known trouble area so it's possible that part is causing the check engine light to come on.
    BTW, the MSRP for that part is $72.01 so the price of $529 is quite excessive. $300 (which would provide for 2 labor hours) would be more reasonable.
    Champion ToyotaWorld
  3. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    One possibility is that your coolant level is low, due to a (very) slow leak in the engine water pump.
  4. aliciadeso
    I don't know what a DTC is or how I would go about finding its log.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    From wikipedia:
    Just ask the dealer for the codes including any sub-codes and post here. Good luck! :)
  6. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    It should be on your estimate paperwork already, such as P1121
  7. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    I agree with Patrick Wong's statement 100%.
    My wifes 2009 Gen II Prius had the same problem. The DTC code is P1121.
    Check Engine Light was on at the time the code was retrieved at Teyas Toyota here in Humble, TX.
    Repairs were as follows with part number and prices.
    Part # 16670-21010 Valve Assy, Water $72.01
    Part # 00272-SLLC2 Super Long Life C $21.51
    Total on Parts $93.52
    Labor $193.19
    Grand Total of Repair $286.71
    Tejas Toyota Humble, TX Date of Repair 7/11/11
    As Patrick stated and others have said elsewhere in the forum, this is a common item to be repaired on Gen II Prius.
    IMHO, you should go back to the dealer who quoted that price and verify the DTC Code. If they don't tell you the code that Patrick and I quoted, go elsewhere and start over. If they do say the code is P1121, then find a dealer that will do the job for less. $529 is NOT a good price.
    AltraStache and aliciadeso like this.
  8. aliciadeso
    Thanks to everyone. The DTC number is nowhere to be found on either the estimate or invoice, so I will call the dealership. I'll post again when I hear back from them.
  9. aliciadeso
    OK Folks -- The codes were P1116 and P1121.
  10. Patrick Wong
    18,200
    6,474
    The DTC is consistent with the diagnosis and the suggested replacement of the coolant heat recovery system valve. The quoted price is quite high; perhaps you can call around to other Toyota dealers in your locale and get a better price.
  11. aliciadeso
    That's exactly what I'm doing!
  12. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Where ever you take it for service, ask them to inspect the engine water pump (not the one that you just had replaced). How many miles on that 2005? If it is more than 80,000, I would take a very close look at that engine water pump. If they find the engine water pump to be bad (leaking), have them do that job first. This also includes a drain and fill+bleed of the engine cooling loop. It is still possible that there just isn't any coolant in the thermos -- also consistent with 1116 and 1121.
  13. aliciadeso
    Thanks, I will.
  14. Landon Lane
    Landon Lane New Member
    Katy, Texas
    I called the tejas toyota dealer today to get a price on the labor for the coolant valve... they said labor alone would cost $410.00. How did you get such a break?
  15. dorunron
    3,318
    1,103
    Houston, TX
    Good question. I would suggest you call back and ask for Kim. Give her the part #'s of the valve, and ask her what the labor rate is. $410 sounds a little high for that job.
    The only thing I can say is that they were doing regular service work for me, plus any repairs I could not handle on my own. Why they quoted you $410 labor I haven't a clue. I don't think their labor rate has changed that much in the last two years.
    AltraStache likes this.
