Check Engine Light
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by theotherone, Jun 30, 2019.
  1. theotherone
    theotherone Junior Member
    67
    24
    Greenville, SC.
    I have a 2010 Prius with 185,000 K, in which I had the local Jiffy Lube change my oil and filter. About 2 days afterwards, the engine started to shake & studder, with no warning lights or codes.
    I checked the dip stick and it appeared that they overfill my oil by 3/4 quart, I had the Jiffy Lube people drain about 1 quart of oil in order for the oil levels to be in between the maximum & minimum marks of the dip stick.
    After they did this, the car ran normally with no shake & studder and/or engine hesitations.
    About one week later, a "check engine" light just went on, which according the manual is a problem with emissions system.
    The gas cap is on tight, but I haven't look through the throttle body. I'm pretty sure the overfilling of oil created disruptions to the throttle body plate and/or air sensors.
    I will try to pull DTC codes tonight with my code reader.
    In the mean time, will continued driving create long term problems with the engine?
    49,487
    no, but i would contact jiffy about repair costs
  3. theotherone
    67
    24
    Greenville, SC.
    I just pulled DTC Code: P0301
    I'm hoping that it's not a blown head gasket, taking it to an independent mechanic tomorrow.
    Raytheeagle and The Critic like this.
    49,487
    check the spark plugs
  5. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Any update?
  6. theotherone
    67
    24
    Greenville, SC.
    So far no updates, I will probably have to wait till after the 4th of July holiday weekend. I'm hoping that it's something simple like dirty fuel injectors, spark plugs/coils/wires, throttle body, EGR valve or MAF sensor.
    It's currently at the mechanic shop.
  7. VFerdman
    VFerdman Senior Member
    1,152
    1,177
    Western Massachusetts
    Cylinder 1 misfire. Clear the code and see if it comes back. If not, then it's most likely due to oil overfill somehow and is/was a transient problem. In the future avoid quick lube places, they have no idea (and/or don't care) of what they are doing in a lot of cases. Good luck!
  8. cnc97
    cnc97 Senior Member
    1,419
    1,528
    38
    Evansville, IN
    3/4 of a quart overfill is not enough to cause a serious issue. It’s just coincidence that this popped up after the oil change. I’d guess that the plugs need replaced. Probably need the slime cleaned out of the TB and the PCV valve changed. If the coolant level is steady then I wouldn’t be concerned with the head gasket.
  9. theotherone
    67
    24
    Greenville, SC.
    Yes, I cleared the P0301 code about 48 hours ago and it hasn't reappeared. The engine feels "rough & hesitant" only when accelerating at low RPMs, but performs normally at higher RPMs.
    I just want to have a mechanic inspect the engine and determine if it's head gasket or other problem.
    I like to be on top of this before it gets worse.
  10. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    When were the spark plugs last changed?
  11. theotherone
    67
    24
    Greenville, SC.
    spark plugs were changed at 100,000 miles
  12. James Powers
    James Powers Senior Member
    396
    555
    Bay Area
    This sounds real similar to the issue that I had. It wasn't a full on blown headgasket as my mechanic put it, rather a head gasket failure in-between #1 and #2 causing the misfire in #1.
    I just saw the HyridPit posted on IG about this as well. The one they fixed was a full on blown headgasket.
    The good news is, if your issue is the same as mine, you wont need new heads, just a quick machining to resurface the current one. As well as replacing a few other parts. Water Pump for preventative, thermostat, things that would have failed in the event a HG did fail completely.
  13. theotherone
    67
    24
    Greenville, SC.
    There was no head gasket leakage, one of the fuel injectors was almost completely clogged.
    We had all 4 fuel injectors inspected & cleaned at an independent shop, then proceeded to clean out the EGR, throttle body, MAF sensor and intake manifold.
    There was a lot of crap built up after 185,000 miles, considering that I only use top tier gas (ie. Costco) and a Techron Complete Fuel System cleaner every 5000 miles.
    So far no trouble codes and the car is running normally.
    The Critic, CR94, bisco and 3 others like this.
  14. bisco
    49,487
    congrats!(y)
