Check Engine Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusjunky, Sep 10, 2011.
  1. priusjunky
    priusjunky Junior Member
    16
    The check engine light came on yesterday. 2004 with 115K. Auto Zone read the codes and they are as follows:
    Definition:
    Idle Air Control Valve control circuit.
    Probable Cause:
    Open or short circuit condition.
    Poor Electrical Connection
    Failed IAC motor
    Any idea where the idle air control valve is located under the hood? I'd like to check for loose or open connections.
    The right rear brake light is also intermittent, but I don't think the two are related.
    All suggestions are welcome.
    Lou
  2. jdenenberg
    jdenenberg EE Professor
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Give us the numerical codes. AutoZone's computer sometimes misinterprets Prius codes.
    JeffD
  3. priusjunky
    16
    P0505 is the OEM #
    Lou
  4. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Prii don't have IACV -- thank God.
    More likely that you have a vacuum leak, a throttle plate stuck open partially, poorly connected PCV hose, or MAF sensor problem.
    Suggested step:
    1. Buy a can of MAF cleaner at same parts store and clean the MAF sensor.
    2. Battery negative disconnect for 5 minutes.
    3. If no joy, proceed to cleaning throttle body, buy can of throttle body cleaner at same parts store.
    4. Battery negative disconnect for 5 minutes.
    5. If no joy, replace PCV valve and hose.
    6. Battery negative disconnect for 5 minutes.
    7. If no joy, take to dealer.
  5. priusjunky
    16
    Thanks, not to good with abbreviations, will look them up. Where is the MAF sensor located. I am assuming that the throttle body is accessible under the air filter, PVC valve should be easy to find.
    Thanks again
    Lou
  6. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    MAF, mass air flow, is attached to the black plastic air intake with two Phillips screws.
  7. jdenenberg
    3,850
    1,843
    Trumbull, CT
    2020 Prius
    LE AWD-e
  8. priusjunky
    16
    Thanks, I'll give that a try. Is there a fuse I can pull that will reset the code, instead of pulling the cable on the battery?
    Lou
  9. priusjunky
    16
  10. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Just so you know, some emission codes don't cause the light to come on until two "trips" have been completed. So you may find it lighting up in a day or two.
  11. priusjunky
    16
    Not sure what the definition of a "trip" is, but so far so good.
    Lou
  12. priusjunky
    16
    It has been a week and the light remains off..Thanks again to all, for the forum and help.
    Lou
