Check Engine related to fuel cap?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SeattleStar, Oct 10, 2008.
  1. SeattleStar
    SeattleStar New Member
    Seattle
    2002 Prius
    After a bit of research through the forums here I have not been able to grasp the exact issue I may be having here. Hopefully someone may have an idea.
    2002 Prius
    102k miles
    Issue:
    When I go to start the car (usually when cold) the Check Engine light comes on, along with the Triangle Exclamation point. The engine runs for a few seconds then stops completely.
    I go out and take the gas cap off and then put it back on tightly.
    The engine then restarts, but the Check Engine light and Triangle stays on. Car seems to run fine.
    Usually after the next 1 or 2 times of turning the engine off then on the lights reset.
    This seems to have something to do with a pressurized/sealed fuel system. However, it just seems to be happening more often.
    I tried a new gas cap with no luck.
    My next step is a trip to get the error codes read, but I was hoping that maybe someone around here had experience with this.
    Little help? :)
  2. nerfer
    nerfer A young senior member
    2,505
    233
    28
    Chicagoland, IL, USA, Earth
    You might be able to pull out the trouble codes from your MFD using this thread. Or find a friend with a ScanGauge or similar product. You might ping Galaxee on this, her hubby was a Toyota service tech.
  3. Patrick Wong
    18,200
    6,472
    Yes, you need to have the DTC read. Note that any codes accessible via the MFD have nothing to do with powertrain issues; hence this is irrelevant to your situation.
    My guess is that you will have the P3191 engine does not start code. I doubt that the gas cap has anything to do with your problem, but hope that you used the correct Toyota part when replacing it. The gas cap should be tightened to at least one click.
    If you have P3191, TSB EG011-03 suggests replacement of the engine ECU once other issues have been ruled out. Since your car is no longer under warranty, this can be a costly repair unless you can find the correct part number ECU as a salvage part.
    You might be able to alleviate the driveability symptoms if you clean the throttle body and throttle plate, and do a tune-up - replace the iridium spark plugs, make sure the engine air filter is clean, and ensure the engine oil is 5W-30 viscosity and not overfilled.
  4. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    yes, please do not mix up my mfd code posting with anything to do with check engine codes...
  5. nerfer
    2,505
    233
    28
    Thanks for the clarification.
    Looks like SeattleStar still needs to find somebody with a Scanguage or go to a service station and get the codes read.
