check engine sign problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Vanne, Oct 24, 2014.
  1. Vanne
    Vanne Junior Member
    65
    Phnom Penh
    Hi all I don't know what happens to my car . I was fill gasoline by today since it left only 1 icon that it mean almost finish and after few hours when I start my engine it has been shown the check engine icon. I'm not sure this cause from above reason or not
    Please help share all experience
    Thank you all
    Vanne
  2. JC91006
    16,827
    8,600
    You probably need to tighten the gas cap, then drive for a while and hopefully the light will go out.
    52,373
    ditto^^^ and if the cap isn't loose, might you have overfilled the tank?
  4. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Tighten gas cap until you hear ONE click. Not necessary to tighten beyond one click.
    I believe there is a replaceable seal on the gas cap as well. This may be another solution.
