Check engine+triangle+like hand break lighy
Discussion in 'Prius v Technical Discussion' started by hashaam, Jun 7, 2017.
  1. hashaam
    hashaam New Member
    17
    us
    Guys i have a issue with my prius today check engine and triangle light and hand break light appears suddenly but now handbreak light has gone but others are still kindly tell me whats the problem and how to fix it?
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Not nearly enough information.
    You need to take it to a shop that can connect a computer device and read the trouble codes.
    Given those codes, folks here might be able to help.
    Are you the original owner ?
    Does it have the original 12 V battery still in it ??
  3. hashaam
    hashaam New Member
    17
    us
  4. hashaam
    hashaam New Member
    17
    us
  5. rjparker
    rjparker Tu Humilde Sirviente
    10,875
    6,829
    Texas Hill Country
    How about some more KEY information. Does it still go to Ready and drive? If not, what happened when it failed? Long period of parking? Low on coolant? Engine fire? Describe as much as you can because, while we are good, most of us are JUST short of psychic.
    Nell262 and Air_Boss like this.
  6. hashaam
    hashaam New Member
    17
    us
  7. bisco
    52,693
    i would test your 12v, make sure the gas cap is tight, and have the trouble codes read.
    how many miles/km on her?
  8. hashaam
    hashaam New Member
    17
    us
    Its almost 123000km drive
    Gas cap??
    If your 12v battery is not good then check engine lights appears?
  9. bisco
    52,693
    a loose gas cap will set the check engine for emissions reasons. a faulty/low 12v can wreak havoc with the computers and set false codes.
