check engine with correct scanner?
Discussion in 'Prius c Technical Discussion' started by tnt4him, Sep 13, 2017.
  1. tnt4him
    tnt4him Junior Member
    Beaverton Oregon
    My check engine light came on, so I scanned to see what my trouble code was. I was shocked that 6 codes came up: 0011, 0002, 0100, 0500, 0020, 0200 I researched each one and found that a lot of them are about open or shorted circuits. However, the car runs fine and being a bit mechanical I know that the car would not run with some of these codes. My question is with the Prius C does it need to be scanned with a special scanner and not the OBDII scanner that I have?
    2012 Prius C 31K
    49,492
    it's probably your gas cap. but yes, prius needs a prius aware scanner. what are you using?
  3. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Gas cap code should be a p410/p411, something around those numbers. You can check it with a normal scanner... ask me how I know. :(
  4. tnt4him
    Beaverton Oregon
    How do I check with the OBDII scanner (the normal scanner)?
  5. tnt4him
    Beaverton Oregon
    I did have 410 and 411 earlier and replaced the fuel cap. These new ones are all about timing and circuits which leads me to believe my scanner is not reading correctly.
  6. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    You plug the OBDII scanner into the OBDII port under the dash.
  7. tnt4him
    Beaverton Oregon
    thanks.
