Check headlights system
Discussion in 'Gen 3 Prius Technical Discussion' started by emad_alquda, Sep 22, 2016.
  1. emad_alquda
    emad_alquda New Member
    Jordan
    Hi . I have a prius 2010 .ii . When turn on the headlights. Low peam or high peam. I see the warning light and message say (( check headlights system )) . So I can't see the hybrid system indicator monitor. How can be fixed it and remove the message Permanently.
    My car laight not LED. it's a halogen .how can me make something to release this proplem.
    #1 emad_alquda, Sep 22, 2016
  2. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    Are you sure it's not Check Hybrid System?
    I've never heard of the Check Headlight System message.
    emad_alquda likes this.
  3. emad_alquda
    Jordan
  4. Mendel Leisk
    40,574
    When you said you don't have LED headlights, I thought that would rule out the headlight levelling system, but now I'm not sure. Maybe take a look under the rear of the car, about the middle of the main rear cross-beam: is there a linkage (Rear Height Control Sensor) between the beam and the underside of the car body? It looks like this:
    Still, I think a trip to the dealership is needed.
    #4 Mendel Leisk, Sep 23, 2016
    Raytheeagle and emad_alquda like this.
  5. emad_alquda
    Jordan
  6. Mendel Leisk
    40,574
    Definitely doesn't look like LED. Ours, LED, for reference:
    Still, check that rear beam, look for that ride height gizmo. If its present, a DIY you could do is to disconnect one end and check that it's joints are moving freely. It's been known to jamb, could be the fault.
    Barring that being the problem, I would be resigned to a dealership visit.
  7. WolfpackBill
    WolfpackBill Senior Member
    349
    500
    Lexington, NC
    Does it have manual headlight leveling...as in a switch on the dash for you to adjust the aim of the headlights? If so, then it could be that is malfunctioning.
  8. Rebound
    Rebound Senior Member
    3,972
    2,626
    Portland, OR
    #8 Rebound, Sep 25, 2016
  9. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Don't know how the different models are equipped in Jordan, and your photo doesn't look like it has LED headlights, so all I can offer is from the USA Owner's Manual:
  10. Rebound
    3,972
    2,626
    Portland, OR
    If you have a halogen headlight bulb installed just a little bit incorrectly, it can melt the headlight housing, which is very expensive to replace. I would look at that carefully.
    Emad, most of us on PriusChat are Americans, so we aren't familiar with any European-only features. In the US Prius models, only the special headlight systems -- HID and LED headlights -- come with the auto-leveling system. But your car is probably Europe spec, and I think to be EU-compliant, a car must have the auto-leveling feature even if it has halogen headlights.
    If you can jack up your car's rear, (and use safety stands!) you can inspect for the linkage which Mendel mentions. Maybe it hit a rock or something. The purpose of the linkage is to measure your car's angle, and then it tells a motor in the headlights to tilt up or down. If the linkage is damaged, you will get this fault. But there are other possible causes, like blown fuse, stuck motor, etc. Sometimes, you just disconnect the 12V battery ground, and then re-attach it, and the computer resets and the problem goes away.
    #10 Rebound, Sep 26, 2016
  11. Mendel Leisk
    40,574
    Yup, checking if this linkage exists is trivial, doesn't even require a jack. I've even unbolted one end (again without need to jack), and rotated the joints a bit to make sure they're not binding at all.
    (May be a 3 poster...)
  12. emad_alquda
    Jordan
    Yes I know. But when pressed display the massage go back with few seconds. I think my headlights is changed. So how can me fix it whitout change the laight .
  13. Mendel Leisk
    40,574
    If you have that linkage, and if it's seized, stuck, it could be the cause of the warning. Please, go 'round the back of your car, look down and under, see if you have that linkage (per the picture above in post #4).
    It may or may not be the problem, but would be good to rule out.
    Guess it's middle of the night where you are. When you get a chance. :)
  14. emad_alquda
    Jordan
    I can't understand about pictures in post number 4 . Please I need really pictures and more details, because I am tired from this proplem
    I have 2010 prius USA . Vin JTDKN3DU3A0050546
    #14 emad_alquda, Sep 29, 2016
  15. kenmce
    kenmce High Voltage Member
    1,544
    515
    NY
  16. Ali198
    Ali198 New Member
    London
    ----UK----
    I
    I have two Prius one is (2015 with halogen headlamps)and (2011 with led headlamps) I swiped headlamps and there’s same massage on 2011 dash that (CHECK YOUR HEADLIGHTS SYSTEM and a Yellow Warning light) but nothing on 2015. can anyone tell me how I can get rid of this
    Many thanks.
  17. Ali198
    Ali198 New Member
    London
    ----UK----
    Many thanks.
  18. Glenn Powers
    Glenn Powers New Member
    Maine, USA
    2015 Prius c
    Prius 2015 C doesn't have this linkage? I looked and don't see it. Help!
  19. Mendel Leisk
    40,574
    AFAIK it’s only on gen 3 Prius with stock LED headlights.
