Check Hybrid System after 12 volt battery replacement
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by djspriusc15, Feb 24, 2021.
  1. djspriusc15
    djspriusc15 Junior Member
    2015 Prius c
    I left my 2015 Prius C sitting too long and couldn’t start it the other day. I picked up a new 12 volt battery and replaced it but now when I start the car I am getting the CHECK HYBRID SYSTEM STOP VEHICLE message. Replacing the battery was pretty straightforward it did I miss a step somewhere?
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,519
    Pacific Northwest, USA
    Did you fully clip down your Orange safety plug? That's usually the problem... Check out a YouTube video on how it's done to be certain.
  3. ChapmanF
    15,635
    Did you fuss at all with the orange safety plug when replacing the 12 volt battery?
  4. djspriusc15
    2015 Prius c
    Didn’t mess with it but I’m going to check it now. Thanks!
    I didn’t mess with the orange plug at all. I’m going to check it now though. Thanks!
    #4 djspriusc15, Feb 25, 2021
  5. bisco
    49,500
    that message should have a related trouble code
  6. PriusCamper
    11,105
    4,519
    Yea... I'm thinking this is a ghost post where they never reply again... But maybe I'm just having a bad day?
  7. bisco
    49,500
    until they prove otherwise...
    PriusCamper likes this.
  8. ChapmanF
    15,635
    Appears to be another case of us carrying on the conversation while the OP sits in the moderation queue.
    There's no particular reason to go check the orange interlock switch if you never fussed with it in the first place. Poster saying it's "usually the problem" may have read your post quickly and thought you replaced the other battery.
  9. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    Did you fully charge the new 12 V battery before installing it ?
    Many come half charged or less.
  10. djspriusc15
    2015 Prius c
    Still getting the hybrid system warning. I made an appointment to take the car into the dealership this week to have them take a look at it.
  11. PriusCamper
    11,105
    4,519
    Don't wast your time with a Toyota Stealership... Find an honest mechanic or friend to help you... The dealership will give you an outrageous repair price and then try to sell you a new car with a "generous" trad-in offer, which isn't generous at all.
  12. sam spade 2
    7,035
    2,788
    2017 Prius c
    Good advice.......NOT.
    While many dealership service departments seem pretty incompetent, independent shops and "friends" tend to know even less.
  13. djspriusc15
    2015 Prius c
    P0B47 is the code that came up.
  14. djspriusc15
    2015 Prius c
    Update. Dealership looked at the car and said the Hybrid System Warning registered code P0B47 and is due to a bad battery smart unit ECU. The actual terms used on the estimate was “Miscellaneous Body Electrical Repair- Battery Smart Unit ECU p0b47 code present”. However they are stating this is not covered under the hybrid system warranty. Waiting for a call from the service manager for more details and explanation.
  15. bisco
    49,500
    it is usually corrosion on the pins
  16. PriusCamper
    11,105
    4,519
    Battery ECU from a Toyota Stealership is $800 and it takes an hour to put in but knowing those crooks they'll probably claim it's a 3 hour job at or above $100 an hour.
    Meanwhile in the real world you can buy a used battery ECU for less than a hundred dollars online and an honest mechanic who doesn't have the costs related to running a huge shop will charge $40 to $80 for one hour of labor to do the job.
  17. djspriusc15
    2015 Prius c
    Shouldn’t this wouldn’t be covered under the hybrid components warranty?
  18. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    I would think it would have to be covered. It wouldn't have a battery ECU if it didn't have a battery.
  19. sam spade 2
    7,035
    2,788
    2017 Prius c
    What you or I or anybody else thinks doesn't matter.
    You need to look at a copy of the warranty that covered your model when it was new.
    The "warranty help line" at Toyota should be able to supply that to you.
  20. ChapmanF
    15,635
    The warranty and maintenance guide is free to download under the Manuals tab at techinfo.toyota.com.
