Check hybrid system code “P0C73” help!!!!
Discussion in 'Prius c Main Forum' started by Billuawan, Aug 28, 2020.
  1. Billuawan
    Billuawan New Member
    Miami Florida
    2014 Prius c
    Hello all I have gone thru this forums before i started this thread
    I purchased and repairs and very minor front hot 2014 Prius c one feom auctions last week. car was run and drive no issues drove as it suppose to when it arrived , drove around the block few times while hit and no such error . I replaced radiator condenser for the vehicle along with front bumper . finalyl got the car back today from repair shop and this sign came in “Check hybrid system turn off the car something “
    Keep in mind 12v battery was dead when it arrived so I didn’t gave jump to the car 2-4 times and it works . I recharged the battery and got it installed again .
    code I scanned is P0c73 .
    Anyone knows what should I check I am getting mixed reviews . Car only have 98k miles on it. 12v battery starts the car perfectly.
    All help is appreciated .
  2. anas abu kaff
    anas abu kaff Junior Member
    jordan
    2015 Prius c
    Possible causes
    Faulty Inverter cooling system
    Inverter cooling system harness is open or shorted
    Inverter cooling system circuit poor electrical connection
    Inverter water pump assembly
    Power management control ECU
    52,757
    pump is the most likely candidate. start by checking the reservoir for movement with the car ready
