Check Hybrid System: Code P0D81
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by funktuna, May 2, 2018.
  1. funktuna
    funktuna Junior Member
    2014 Prius Plug-in
    2014 Prius Plug-In 85,000 miles
    Originally my girfriend plugged in the car and the next day it had the yellow warning light and said Check hybrid system, pull over to a safe location. The car started and drove fine but the battery was low. I figured there was an electrical issue in the house while charging or she didn't plug it in correctly. Anyways I pulled the code with torque and got P0D81. I reset the code and all has been good for a month. Now the same thing happened where I only had 1 mile on the battery and the same warnings as before. I was using a different charging cable this time, so I don't think that is the issue. I plugged it back in after taking it for a spin and it charged fine.
    Has anyone else had this issue? My google research doesn't give me much information on this code. Is Torque not able to read the more detailed codes that Toyota would see? I haven't pulled the codes this time around yet.
    52,390
    hard to say, you might be fine. of course, it is always a good idea to use tech stream.
    it might be worthwhile checking/cleaning the battery cooling fans, ductwork and intake grilles.
  3. Erik Owens
    Erik Owens Member
    162
    59
    DTC
    P0D81-643
    Input AC Voltage Malfunction
    [​IMG] .
    DTC NO.
    INF CODE
    DTC DETECTION CONDITION
    TROUBLE AREA
    P0D81
    643
    VAC sensor voltage is out of the specified range (too high or too low). (1 trip detection logic)
    • Electric vehicle charger assembly
    • Plugin charge control ECU assembly
    Related Data List
    DTC NO.
    INF CODE
    DATA LIST
    P0D81
    643
    • On-Board Charger Input Voltage
    • Charging Control Status
    • Voltage with Charge Cable Connected
    • Charge Cable Inserted
    • Charge Cable Engaged
    [​IMG] .
    GO TO DTC CHART (PLUG-IN CHARGE CONTROL SYSTEM)
    A
    [​IMG] .
    (c) Enter the following menus: Powertrain / Plug-in Control / Data List
    (d) Select "On-Board Charger Input Voltage" in the Data List.
    TESTER DISPLAY
    MEASUREMENT ITEM/RANGE
    Effective AC voltage (VAC sensor value) input to the electric vehicle charger assembly from the charging inlet/
    Min.: 0.0 V, Max.: 6553.5 V
    (e) Set the tester to measure the following terminals.
    ITEM
    CONTENT
    Terminal
    z12-23 (VAC) - z12-21 (CGND)
    Tester Setting
    AC Voltage Range
    Text in Illustration
    *a
    Component with harness connected
    (Plugin Charge Control ECU Assembly)
    (f) Start plug-in charging and compare the Data List item "On-Board Charger Input Voltage" with the following value: actual measurement of VAC terminal voltage x 1000/7.
    RESULT
    PROCEED TO
    The difference between "On-Board Charger Input Voltage" and "actual measured voltage of VAC terminal x 1000/7" is less than 60 V
    A
    The difference between "On-Board Charger Input Voltage" and "actual measured voltage of VAC terminal x 1000/7" is 60 V or more
    B
    (g) Turn the power switch off.
    (h) Stop plug-in charging the vehicle.
    B [​IMG]
    REPLACE PLUGIN CHARGE CONTROL ECU ASSEMBLY
    A [​IMG]
    REPLACE ELECTRIC VEHICLE CHARGER ASSEMBLY
    [​IMG] [​IMG]
