"Check Hybrid System" every few months
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ahernandez1622, Oct 15, 2018.
  1. ahernandez1622
    ahernandez1622 New Member
    New Orleans
    Hello! I bought a used 2012 Prius C from a local used car dealer a little over a year ago. Since then, I have received the "Check Hybrid System" message three times. The first time, I brought it into the dealer and they said they found a strange substance coating the battery that they were able to remove without damaging the battery itself. The second time, they said that they had identified an issue under warranty (didn't specify over the phone and I can't find an invoice) and would replace the entire battery free of charge. Now, a little over a month since that last visit, and the message is back! My car has 71K miles on it. Any ideas or thoughts? I plan to bring it into the dealership tomorrow, but would love an outside perspective as well. Thanks!
  2. Leadfoot J. McCoalroller
    7,176
    6,728
    Pennsylvania
    2018 Prius c
    The car's got an interesting history. With the timing you mention, I have to wonder if it was cleaned up from hurricane Harvey & migrated eastward...
    Anyway, it's tough to tell without getting the data dump from the car. You can tool up to do this yourself, and it can be surprisingly cheap and easy. If you've already got an android phone or tablet, you can get an app and interface that lets you interrogate the car.
    One thing I've heard a lot about the prius c in particular- the car is sensitive to battery temperature; lower is better. The high voltage battery under the back seat breathes air through a fan and some ductwork on the sides of the heel boards under the seat edge. Check the ducts for obstructions, maybe vacuum them out if pet hair gets in the car.
    ahernandez1622 and dubit like this.
    49,506
    welcome!
    anyone cleaned the battery cooling fan yet?
    ztanos likes this.
  4. PriusCamper
    PriusCamper Senior Member
    11,105
    4,520
    Pacific Northwest, USA
    So was it a clean title? Or salvaged? That would explain alot...
    As for strange substance they cleaned... If it's not flood damage and they're sure it's not battery acid, it most likely something that's been corroded by a battery acid leak and it's hard to see battery acid sometimes. Last week I sprayed down a hybrid battery chassis with vinegar and then some green cleaner and even though it looked entirely cleaned, the next morning, thanks to super wet weather, the vinegar and cleaner never dried and most of the whole chassis was white with all the battery acid that got oxidized. I say all this because perhaps they didn't do a very thorough job cleaning away all the battery acid and "strange substance" and it led to rapid corrosion soon as the electricity started flowing and now the voltage sensors they didn't clean now need to be cleaned. There's lots of other things, but that'd be my first suspicion....
    ahernandez1622 likes this.
  5. ahernandez1622
    New Orleans
    I'm not sure if that would have been cleaned or replaced when they replaced the hybrid battery, but I can definitely bring it up when I take the car in. I do have a German Sheppard that loves car rides, and have slacked on keeping the back seats vacuumed.
  6. bisco
    49,506
    that can be a major issue
  7. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Since you've got a new battery, I doubt it's got any issues...
    I can't guarantee the dog is the problem, but I'd wager a few dollars to say that the dog hair and lack of vacuuming is clogging the screen on that cooling fan. Which if clogged, you'll get a message to check the hybrid system. The screen is very easy to clean and you'll be surprised at how quickly it can become clogged. I'll link to a video...
  8. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Did you pay for a CarFax report?
    Did someone with more automotive knowledge/expertise check out the car prior to purchase?
    You purchased the vehicle from an independent lot, NOT a Toyota dealer?
    Who is performing this "warranty" work? The independent used car lot or the Toyota dealer?
    What battery was replaced? 12V battery or the Hybrid Battery? If it truly was the Hybrid Battery, is there physical proof that they replaced it with the an OEM Hybrid from Toyota? Where is your invoice showing this to be the case?
