"Check Hybrid System" onward to Dealership Warranty
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by sguerra923, Jul 23, 2019.
  1. sguerra923
    sguerra923 Junior Member
    48
    San Diego
    So I got the check hybrid system check engine light on so I decided to go ahead and clean the hybrid fan which was dirty and reset the 12v battery and it cleared the check engine light drove it for over a hundred miles and it came back on again. I've kept up with maintenance with the Prius and got the EGR replaced under warranty. The good thing is when the check hybrid system came on the car was still drivable there was no misfires so hopefully it's just the Hybrid battery.
    So since my 2010 Prius is still under warranty with the hybrid system I'm having it towed to the Toyota dealership service department. Just out of curiosity, has anyone had their Hybrid battery replaced under warranty? And how was your experience?
  2. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    CEL doesn’t default to an issue with HV fan or battery. For a starting point, plug an obd2 reader to retrieve the code(s). Codes will tell you where to begin troubleshooting.
    Or put your extended warranty to use :)
    Raytheeagle likes this.
  3. sguerra923
    48
    San Diego
    Unfortunately, I don't have a OBD2 reader. I was already having symptoms of my Hybrid battery discharging really quickly. I would be traveling on just electric and I can see on my dash the bar is going down one by one. I have a 130 k on my car ready.
    52,650
    when traveling on electric, that's what the battery icon does, you're using up the battery.
    when the dealership pulls the codes, they will notify you of the problem. if it isn't the battery, hopefully it is some other warranty item, although there isn't much else left under warranty, emissions i think.
    if it is the battery, you will get a new one on toyota. keep your fingers crossed!(y)
  5. sguerra923
    48
    San Diego
    Yeah I understand that the battery icon does go down when you're on pure electric if it didn't then I have a super electric car lol but it shouldn't go down every second until it's down to the last two bars.. that's what I'm trying to say
    Yes, fingers crossed on a new battery. But like my original thread says has anybody done a warranty exchange with their Hybrid battery?
  6. bisco
    52,650
    yes, many have, but you'd have to search to find them, unless they come across this thread. but the title won't attract them
  7. vtwin_pilot
    vtwin_pilot Junior Member
    Atlanta
    I didn't have the battery replaced under warranty, but my 2010 about 5 yrs ago had a failed inverter, which the dealer replaced totally for free under warranty.
    bisco and sguerra923 like this.
  8. teiresias
    teiresias Junior Member
    61
    Hampton, VA
    I just had a "Check Hybrid System" today as well on my 2011 Prius with about 125k miles. It threw it this morning when I went out to leave for work. Car was totally unable to be put into a drivable state, although all the electrics came on which told me it likely wasn't anything to do with the 12V battery. I've had a totally dead 12V battery before and the car simply doesn't do anything in that state when started (no beeps, nothing).
    Had it towed to the dealer who called and said it was the Inverter IPM that would need to be replaced, and would be no cost due to that IPM warranty extension that Toyota put out.
    #8 teiresias, Jul 23, 2019
  9. sguerra923
    48
    San Diego
    so I got the call back from Toyota service and they determined it was the Hybrid battery going bad and they will replace it covered under warranty. Thank you hybrid gods!
  10. Grit
    Grit Senior Member
    6,577
    4,230
    Wilkes Land
    Congratulations, that’s hitting the hybrid battery lotto.
  11. sguerra923
    48
    San Diego
    Thanks I'm definitely grateful I'm able to get a new one installed under warranty
  12. bisco
    52,650
  13. sguerra923
    48
    San Diego
  14. bisco
    52,650
    congrats!(y)
  15. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    I guess he doesn’t share your same excitement :(.
    But not a bad deal(y).
  16. Meghan1183
    Meghan1183 New Member
    Raleigh
    This just happened to me last night! Dealer is checking it out now and said they suspect what’s happening and that it’ll probably be fixed under warranty. I breathed a sigh of relief when he told me that. Still, I’m devouring threads about this issue in case it’s something else...
