Check Hybrid System, P0A0F / P2111
Discussion in 'Prius c Technical Discussion' started by Zradub, Sep 6, 2024 at 2:17 PM.
  1. Zradub
    Zradub Junior Member
    36
    My new to me 2016 102k mi C got this yesterday:
    is it the tb or it’s sensors or maybe a Maf or fuel pump?
    49,752
  3. ChapmanF
    15,942
    It's not going to be MAF or fuel pump, or anything besides the throttle body, throttle position sensor, or the wires thereto.
    The code tells you the ECM wanted the throttle to close but did not see the position sensor showing it closing.
  4. Zradub
    36
    So is first step to simply clean the throttle body? If that doesn’t work how do I test the TPS or TB itself?
  5. ChapmanF
    15,942
    Cleaning the throttle body won't hurt, I guess, but might not lead directly to any insight into why it wasn't seen closing when the ECM wanted it to.
    A good scan tool should be able to pull up the freeze frame from when the P2111 code was set, and show just what the position sensor readings were at that moment. There may also be active tests where you can command a specific throttle position and see the position reading.
    There should be a whole recommended troubleshooting procedure in the section for P2111 in the repair manual:
    Toyota Service Information and Where To Find It | PriusChat
    Brian1954 likes this.
