Check hybrid system stop immediately message
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Syed Ashar Ali, Nov 13, 2020.
  1. Syed Ashar Ali
    Syed Ashar Ali Junior Member
    77
    Houston, TX
    2014 Prius c
    Hi I have a 2014 prius c. With 105, 000 miles. It was working perfectly until today I put in premium gas. Not sure that's what it caused but now there's a message check hybrid battery. Po84a code. Also on idle it is not going to charge mode. It stays on gas all the time. And on the drive information it says ev but no % being used. On the energy monitor I can see the battery bar is 4 bars at least. But no energy is working. It's just still on the energy monitor. Any idea if this is the hybrid battery or something else? Worth going to dealer to get it checked out? Will the car eventually shut off if I keep driving if that message comes? Thanks
  2. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Hi I have a 2014 prius c. With 105, 000 miles. It was working perfectly until today I put in premium gas. Not sure that's what it caused but now there's a message check hybrid battery. Po84a code. Also on idle it is not going to charge mode. It stays on gas all the time. And on the drive information it says ev but no % being used. On the energy monitor I can see the battery bar is 4 bars at least. But no energy is working. It's just still on the energy monitor. Any idea if this is the hybrid battery or something else? Worth going to dealer to get it checked out? Will the car eventually shut off if I keep driving if that message comes? Also the warning lights are yellow. Thanks
    #2 Syed Ashar Ali, Nov 13, 2020
  3. Tideland Prius
    16,128
    *Threads merged*
  4. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Any ideas buddies?
  5. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    I'm not much of help when it comes to codes. hopefully someone will chime in here.
    But I will say that the Prius C hybrid battery seems (around here anyways) to have about a 5 year life. Toyota's warranty is 8 years/100,000 miles. While your over, your barely over that limit. If the hybrid battery does need to be replaced hopefully they will goodwill warranty some of it.
    I would not drive the vehicle however. If it says stop immediately, I'd adhere to that. lol After all, it's telling you that for a reason.
  6. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Is it possible a cable got disconnected while driving which is causing it to not making the electric engine start? This literally just happened while I was driving after I hit a pot hole
  7. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Update : prius tech checked it. ( not the Toyota dealer). And said 6 of my cells were low. He said I can continue driving it. It's not an emergency but the " check hybrid system immediately" message will stay on. I decided to get it fixed. Quoted me $850
  8. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Update : running again good as new back On road.
    Told me my fan was filled with debris etc
  9. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    So what did they do for $850???
    That fan is below the back seat right behind the driver and can be cleaned in less than 10 min. If I recall correctly, I do believe I have read here on PriusChat that others had gotten that message when the fan was clogged as well. Hopefully that's all it was.
    But wow = $850 out the door.
  10. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Update : just got the message again " check hybrid system immediately" after repair
  11. AzusaPrius
    AzusaPrius Senior Member
    1,840
    811
    Go back right away and find out exactly what they did for $850 and have them check codes and make sure what they did was good.
  12. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Soo.... He rechecked it and said "all the batteries are in the right voltage. But it maybe a ecu issue or rebalancing the batteries because he didn't get to do that last time. He said" bring it tomorrow morning " no additional pay needed since it's in the warranty
    Surpringly, when he got redone checking and gave my keys back, the" check hybrid system immediately " message dissappeared. And everything is back to normal. However I have a feeling that message will pop up again today or anytime.
    So giving the car tomorrow morning
  13. Syed Ashar Ali
    77
    Houston, TX
    2014 Prius c
    Oh shuks.. Just what I was afraid of. "check hybrid system" message came back
  14. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Just a heads up. If you end up needing to replace the hybrid battery. Go with a new Toyota battery. Don't waste your money on the rebuilt one's. Literally hundreds of threads on here of people going the "rebuilt" route only to end up with another failed battery within the year.
    I'm not sure how much the C's battery is at the moment. But you have a car with some low mileage. Get that battery replaced and you'll be running for another 150 k
  15. Leadfoot J. McCoalroller
    7,138
    6,684
    Pennsylvania
    2018 Prius c
    Looks like it is just barely out of warranty- take it to Toyota and see if they will work with you anyway. They've done it before, though they are under no obligation.
  16. RobAustin
    RobAustin Member
    104
    51
    Austin, tx
    If the battery pack has failed I also suggest replaceing the whole assembly with a Toyota OEM unit.
    I purchased mine from LKQ w/ low milage for $850+tax.
    Took us less than 90 mins. to install using hand tools.
    Rob
    2012 Prius C1
    My Experience:
    Hybrid Battery Failed - 2012 C | PriusChat
