Check hybrid system warning, prelim diagnosis
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by drjeremiah, Jan 16, 2023.
  1. drjeremiah
    drjeremiah New Member
    Los Angeles
    1/14, the check hybrid system stop vehicle in a safe place warning came on in my 2012 prius 3. i was able to drive 4 miles home at 30mph with no issues. car has 162k miles, bought new, always serviced at dealer, no major repairs (just brakes/filters). I have been driving it 2-300 miles/month since 9/22, and it's been parked in the heavy rains we've been having (no flooding). today it was sunny out. so i went to run basic diagnostics with Dr Prius and came up with the attached readings. not sure how to decipher. the car will start and drive, but in limp mode. also, sometimes the engine will run, other times it won't kick on. i noticed when i stopped the engine it went to bed with a rattle sound (I didn't try to repeat it). the car has original plugs (was about to change in the next few weeks). i am thinking it might be the plugs, EGR (the rattle), maybe the HV battery (and/or fan), or the 12v battery. I haven't disconnected 12v yet, as I don't want to clear the codes. suggestions/recommendations would be most welcome. I called a mobile mechanic to come out and run the full diagnostic check for $150. i'd like to keep her...she's been good to me, she drives well, and she isn't encumbered with a loan.
  2. Tombukt2
    Tombukt2 Senior Member
    13,059
    2,340
    Durham NC
    Well you're right in the range of the wonderful Gen 3 death arrival lower end issues I've had them in a persona 2013 change the whole setup running wonderful others have done all kinds of things just beware of what happens to the open deck design and go from there it's not a real fun project but oh well you're right at the mileage this is like the perfect storm at this mileage.
  3. Mendel Leisk
    41,548
    My 2 cents: the carbon-clogged EGR system does not cause the start-up rattle; it causes temperature rise/imbalance in the combustion chambers, that causes the head gasket to fail (almost invariably between cylinders one and two), the head gasket failure allows coolant to seep into the cylinders, and that causes the start-up rattle.
    To check head gasket integrity: try a leak down test and/or boroscope inspection of the combustion chambers with coolant system pressurized.
    Once the head gasket viability is sorted out, get on the EGR system cleaning without delay.
    There's links in my signature regarding head gasket replacement and EGR cleaning.
    This is the sand-pounder.
    #3 Mendel Leisk, Jan 17, 2023
  4. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Since check engine light codes are only $20 to buy a code reader at the store isn’t an option, then get the mobile mechanic to get them for you for $150 then come back and post the codes.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I would definitely have thecodes read from an auto parts store for free instead of the mobile mechanic.
    Were you planning on changing the spark plugs yourself? If so, you can buy a Milwaukee, Boroscope for less than 150 you were going to spend on the mobile mechanic.
    #5 2010moneypit?, Jan 17, 2023
  6. CR94
    CR94 Senior Member
    2,697
    1,174
    Northwestern S.C.
    I don't believe a brief temperature spike that lasts only a tiny fraction of a complete combustion cycle will bother the head gasket, BUT the associated pressure spike might.
  7. ChapmanF
    18,257
    Agreed. What spikes in temperature during that tiny peak is the moving small volume of air and fuel that will quickly heat, just as quickly expand and cool, and shoot out the exhaust valves.
    What happens to the temperature of the head gasket depends much more on what happens to the temperature of the two large masses of aluminum it is clamped between and of the coolant circulating around them.
    For what it's worth, aluminum's specific heat (the amount of energy needed to raise the temperature of m grams of aluminum by n degrees) is pretty high, nearly double that of steel, very close to that of concrete.
    2010moneypit? and CR94 like this.
  8. drjeremiah
    Los Angeles
    Update: Appreciate the replies. I went ahead and changed the plugs myself. Took all of 30mins, not bad at all. Started the Prius, warning light came on, but then the ICE cut out (seemingly going into hybrid mode). I turned off the car. I started it again. The engine turned on, and after letting it run for a good 4mins, I turned it off and the rattle occurred (incidentally, it was never a start-up rattle, but rather a brief 1-2 second rattle upon turning off engine). Anyway, I took one poster's snarky comments re the $20 OBD scanner. I got one from Amazon, it spit out no codes. I had another delivered a few days later, tried the same drill, but again, no codes. Oddly, after trying the second scanner, I turned the car back on and the warning msg was gone. I drove the car around the block, maybe 1.5 miles, thinking all was well in the world, but the "check hybrid system/stop" warning reared its head again. The 12V battery reads 12.3V (changed it in 2015, so it's almost 8 years old?). My next course of action will be to check the hybrid fan. I noticed I didn't hear the fan turn on the last 2x I started engine after plug swap (and during the short drive). Can a bad EGR bring up the particular warning message I'm getting? Additional ideas/thoughts are welcome, before I bite the bullet and take it to a local mechanic for a deeper (and hopefully, final) prognosis. Thanks. JR
  9. Mendel Leisk
    41,548
  10. drjeremiah
    Los Angeles
  11. 2010moneypit?
    314
    122
    Beaumont ca
    Unfortunately not all scanners will read the codes on the hybrid side of the Prius.
  12. drjeremiah
    Los Angeles
    Update: car has been sitting for a week, no starts; this is 2 weeks since plugs were changed. Yesterday, I started it, smooth engine, and just the check engine light turned on, no Check Hybrid Status. I let car do its usual cycle into hybrid, let it run for 3 mins, then rolled it into the driveway to dismantle/check/clean the hybrid cooling fan. That went well, the fan showed no great dust build-up. Reassembled fan. Then I plugged in a new OBD scanner, and <drum roll> this one pulled up codes. I assumed these were from before I swapped the plugs out: it was cylinder misfire x 4. I cleared those codes, and the check engine light also went by the wayside. I test drove the car around the block 2-3 times, and the engine had noticeable pep, like when she was new. I parked it and let it run another 3 minutes, no sign of the spooky warning OR the engine rattle when I turned the engine off. I am still going to clean EGR pipe. So, for this repair session total outlay thus far: iridium plugs ($55), OBD scanner ($25), new DeWalt impact drill and bit set ($125). Will update.
    Siward and CR94 like this.
  13. drjeremiah
    Los Angeles
    Additional post-spark plug change update (3/5/2023). I currently drive the car 2x a week (it's a third car). I most recently logged 30 miles driving around town. The acceleration in Power mode seems to be back, courtesy I assume of the new plugs. Warning lights haven't come back since the plug change and my using an OBD scanner to clear the cylinder mis-fire codes. I want to thank you all for the advice, especially the bloke who suggested I buy a $25 OBD scanner rather than pay a mechanic $150 to do the scan for me! Ciao. JR
