Check Hybrid system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Skunkworks, Aug 4, 2015.
  1. Skunkworks
    Skunkworks Member
    101
    I was recently having some AC issues, I dropped the glove box to check the cabin filter, That's when all hell broke loose., I noticed a plug in one of the boxed was loose, I pushed it in and the car started beeping, so I shut the car off, then started it, Its park brake was stuck, so I tried everything from disconnecting 12v batt, to disconnecting the hi voltage batt and then both. Now it wont run, wont do anything and throws no codes. Please help. Is there a way to reset?
    51,139
    did you slide the orange connector properly after locking it?
    did you try unplugging the plug that was loose? is the parking brake still stuck? look at your 12v connections including ground to chassis.
  3. Skunkworks
    Skunkworks Member
    101
    Yes, I have triple checked everything
  4. JC91006
    16,672
    8,518
    did you check if your 12v battery was good?
