Check Hybrid System
Discussion in 'Gen 3 Prius Technical Discussion' started by Abu Rais, Oct 28, 2017.
  1. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Last Night I drove the car find came back home part of the car and this morning in the actual in the afternoon I try to start the car for first two times he didn't starred says check hybrid system and then the third time the car started but we did check hybrid system message and the sign on the left.
    I'm clueless at this point what to do some guidance would be highly appreciated
  2. makbg1
    makbg1 Junior Member
    35
    LA
    What year is your Prius?
  3. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
  4. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    I took the car to AutoZone to see what is the code but the code reader sees there is no code. The light was still on to check the hybrid system and the Triangle exclamation sign.
    Then we turned of the car and check the 12 V battery and the battery tested hundred percent good. After that I restart the car and there is no code no sign back to normal again.
    At this point I don't know what was wrong but the car is back to normal again no more message on the dashboard
  5. bisco
    51,140
    might need to clean the hybrid battery cooling fan, make sure the intake grille is clean, and not blocked by anything. how many miles on her? is the 12v original? those tests aren't always accurate, and the code readers sometimes won't recover prius codes.
    #5 bisco, Oct 28, 2017
  6. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    195 k miles
    12v battery is going to be three year old in November.
  7. Abu Rais
    Abu Rais Member
    58
    42
    Houston, Texas
    Same situation this morning. Car wouldn't start and Check Hybrid System.
    After attempting more than 10 times car started.
    Then followed Nutz and Boltz video for Maintenance mode and then turn it off.
    After that no more check Hybrid System message.
    I am so frustrated with this situation. Wish to sell it and move on.
  8. bisco
    51,140
    i would test the 12v just to be sure.
    Danny3xd likes this.
