check hybrid system
Discussion in 'Newbie Forum' started by Monica72, Jun 16, 2019.
  1. Monica72
    Monica72 New Member
    Albuquerque, NM
    Please I have a code that said that I need to change the battery pack, but, I am trying to change just the block V04, I have a prius C 2012 how do I know which one is it? Is it A or B?
    49,371
    welcome!
    the service manual will tell you, or you might find a video on line
    Skibob likes this.
  3. mikey_t
    mikey_t Active Member
    370
    391
    Los Angeles
    Your 2012 hybrid battery may still be under warranty. Have you asked your dealership to check?
    Raytheeagle, Mendel Leisk and Skibob like this.
  4. PriusCamper
    PriusCamper Senior Member
    11,055
    4,499
    Pacific Northwest, USA
    Block 1 module usually starts on the opposite site of all the electronics gear attached to the pack... I've not worked on a Prius C pack, but from your pic it looks like gear is on the right so block one is on the left and A would be the correct answer. But why not do a voltage test on all the modules to be sure you're being thorough?
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,369
    3,217
    Madison, Wisconsin
    Block one starts at the negative cable.
    For some reason I can't see your photo but hopefully that helps.
