Check Hybrid System
Discussion in 'Gen 3 Prius Technical Discussion' started by johnjeric, Jul 13, 2020.
  1. johnjeric
    johnjeric Junior Member
    Hi friends,
    I am getting the "Check Hybrid System" light and I don't know what to do. I had my tires services and car maintenance serviced all within the past 10 days and then a few days later, this light comes on. I am thinking maybe something was accidentally touched during car tire repair, or during oil change/vehicle inspection. Also, I just had the hybrid battery replaced by Greenbeanbattery 3 months ago.
    The car starts and is able to drive. I actually was able to drive it home 50 miles when the light first came on. When looking at the battery/engine/transmission guage bar while driving, everything looks like it is working fine.
    My local toyota dealership and my scanner said that there are no codes to read. I think that this message just needs to be reset, and if it comes back on, then there may be an actual problem. It would cost $200 to get a diagnosis from my local Toyota. Greenbeanbattery will not do anything unless I can provide them with the error code.
    Does anyone have any thoughts or insights? I'd greatly appreciate it! Thank you.
  2. ASRDogman
    ASRDogman Senior Member
    6,073
    3,264
    This is the chance you take when you get a used battery, from green bean. They us used batteries....
    Check the voltage of the 12v battery. A low battery will give you all kinds of warning lights.
    If it is more than 5 or 6 years old, replace it.
    #2 ASRDogman, Jul 13, 2020
  3. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Which OBD2 scanner, OBD2 wifi/bluetooth adapter, or OBD2 App might you be using?
    Many prefer a 'mini-vci' cable and techstream (dealer tech level software) on a windows device (or Oracle VM VirtualBox )
