Check Hybrid System
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Newpriusguy57, Nov 10, 2020.
  1. Newpriusguy57
    Newpriusguy57 New Member
    New Jersey
    Hi everyone. My 2013 Prius (130k miles) is displaying the "check hybrid system" message, along with the check engine, yellow triangle, brake system, and slip indicator lights. It's at my normal shop now and they've said the inverter is bad and will cost $4000 to completely replace, or $3500+ to go in and try to find out which particular component(s) has failed.
    The codes it's showing are: P0A7A, P0A94, P324E, C2124, C1259, and C1310. Does this diagnosis and cost seem right to you guys? I checked with Toyota and they said the extended inverter warranty (15 years/150k miles) doesn't apply to my Prius.
    I'm not much of a DIY guy and I don't have access to tools further than a couple screwdrivers, so I can't do much myself. I would greatly appreciate any suggestions on where to go from here.
    Thanks!
    51,140
    did you have the ipm recall done?
    pjksr02 and scona like this.
  3. pjksr02
    pjksr02 Active Member
    532
    226
    Connecticut
    To see if you have an outstanding recall, put your VIN into the NADA recall search, or create an account at the Toyota Owner site, and search.
    scona likes this.
  4. Newpriusguy57
    New Jersey
    I don't have any outstanding recalls, but Toyota said I might qualify for the warranty enhancement program ZE3, which would replace the IPM under warranty. I'm having the Prius towed there tomorrow so they can diagnose and see if it qualifies.
    pjksr02 likes this.
  5. boywander
    boywander Junior Member
    37
    Washington
    So what did the dealer say about the diagnosis?
  6. Newpriusguy57
    New Jersey
    The dealer said it qualifies for the ZE3 program and they fixed it at no charge! I got it back on Friday and it's running fine again.
    tvpierce, pjksr02 and scona like this.
