Check Hybrid warning system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by monahj, Jan 24, 2016.
  1. monahj
    monahj Junior Member
    25
    16
    Hyannis, ma
    Just started up my car and the "Check Hybrid warning system" came on, along with a check engine light. The car starts and moves, but I'm unsure if I should drive it to the dealer two miles away without doing any further damage to the vehicle or have it towed. The car has 130000 miles and is serviced every 5000 at the dealer with all recommended maintenance performed. Thanks, Jim
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Still on original 12v battery? How old is it?
    monahj likes this.
    49,371
    fortunately, you're still under the hybrid warranty. have triple a?
  4. monahj
    25
    16
    Hyannis, ma
    I have owned it since 2014, so its possible its the original battery. Just had it serviced 3 weeks ago and everything was up to specs. Vehicle starts. I do have AAA.
  5. bisco
    49,371
    you can have it flat bedded to the dealer for free. they can also test your 12v, but they don't really understand hybrids.
    monahj likes this.
  6. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    You are in a "CARB" state, therefore as long as the car was originally sold in a "CARB" state, the hybrid portion of the car should be under warranty. With that said, I would contact your local dealer and have the car checked out by them.
    It might be a weak 12 volt battery, or it might be something else in the hybrid section of the car.
    Until the codes are pulled, you really are guessing.
    FWIW, I don't believe driving it two miles to the dealer will hurt it. YMMV
    Best of luck to you.
    monahj likes this.
  7. monahj
    25
    16
    Hyannis, ma
    Thank you for all the fast replies. Since I'm paying for Triple A, just going to have it towed for free. Hopefully it's nothing major. Thanks again, Jim
  8. bisco
    49,371
    please keep us posted, all the best.(y)
  9. turboj91
    turboj91 Junior Member
    16
    CT
    I had to disconnect my LV battery due to a collision loss (minor front end damage). Reconnected the battery and attempted to start the car. The "Check Hybrid System" warning is displayed and the car will not start or go into "Ready" status. It will power up and accessories will work (radio) but that's it. Cycled the start button 4 or 5 times to no avail. Any thoughts??
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    Cycle it a few more times, may need up to ten times to clear. If it still doesn't clear, there may be a shorted wire somewhere, especially near the front end damage.
  11. monahj
    25
    16
    Hyannis, ma
    Update: I did have the car towed. Dealer came up with the following codes: P3190, P3191 and P0A0F. I had a bad Vacuum Switching Valve and since it was part of the hybrid system, it was covered under warranty. Again, thank you for your replies. Jim
  12. turboj91
    16
    CT
    Thanks Xliderider,10 cycles worked like a charm.The gas motor started and idled for 5 minutes then shut down and the electric motor took over just like old times.I appreciate your quick response and accurate solution.
    xliderider likes this.
