Check PCS system lights turn on every time it rains.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Rainking, Dec 31, 2024.
  1. Rainking
    Rainking Member
    164
    New York
    What could be causing this? Once it stops raining and dries up, no issues but immediately turns back on when it starts raining.
    2012 Prius Plug-in Advance
    Thanks!
  2. PriusCamper
    PriusCamper Senior Member
    11,977
    4,868
    Pacific Northwest, USA
    I'm not sure how these systems are calibrated, but that's the problem. First thing you can try is to disconnect the 12v battery for a few minutes, which will reset the whole car to original settings when it rolled out of the factory. Next step would be to go through any settings available on the dash related to this. Then next step would be checking out the settings available in Toyota Techstream running on an old laptop.
