Check PCS system warning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by quasi, Sep 20, 2014.
  1. quasi
    quasi New Member
    Sydney, NSW
    got a "Check PCS system" on MFD with blinking PCS light and yellow triangle lit. when stationary, cruise control says "Radar ready" but once moving it says "Check cruise control system".
    no real work done to car or anything special happened at the time. it was working fine and then one morning when starting we found the warning.
    anyone have any ideas on anything else i can check?
    i've gone through forums and have tried the following so far:
    - changed auxiliary battery (this was low on power)
    - checked PCS button under dash
    - checked onboard diagnostics and its showing a speed that matches the display speed while driving (i assume that means radar sensor is working)
    - have cleaned radar sensor
    - tried resetting ECU/codes: battery unplugged and also car on/off 5 times
    - checked OBD2 codes (have ordered a check J2534 cable but took it to Toyota and they claim no codes although i don't know if i believe them)
    we park on a steepish driveway so reading the other tread about the PCs warning after a spring change, i'm going to check if the front wheel speed sensors are plugged in correctly (although i assume the onboard diagnostics check kind of did that as well since i think it compares speed from the wheel sensors and the radar system)
    #1 quasi, Sep 20, 2014
  2. Abdul sattar
    Abdul sattar New Member
    Same problam with my car itried many tecnitions but not solve
  3. Katie preston
    Katie preston New Member
    Az
    I have had the same issue w my Prius v
    Any resolve?
    49,353
    welcome!
    has the dealer been unable to solve it? any trouble codes?
  5. Katie preston
    Az
    No last year i took it in and they read the codes and all came back fine.....it’s just strange that after a year the Check PCS warning light randomingly came on again?
  6. bisco
    49,353
    sounds like a bug. disconnect the 12v for a few minutes.
  7. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    There is a PCS on/off switch under the dash, just like the TPMS set button. Take a flashlight and put your head on the floor looking up and you can find it. It's labled "PCS". The other switch under there is labled "SET", for the TPMS.
    If your yellow "PCS" light is on solid that switch is turned off. I run all the time this way because I don't want PCS to function. Cruise still works just fine with PCS off (DRCC).
  8. Katie preston
    Az
    I have done that and even when the PCS system is OFF the check PSC warning light comes on?
    Thank you!
  9. Katie preston
    Az
    How do I disconnect the 12v?
  10. bisco
    49,353
    open the hatch and remove the floor. then remove the triangular floor piece in the right wheel well. you will see the battery down there. loosen the negative connection not and wiggle till it comes off. wait a few minur=tes and reverse process.
    there may be pics in the o/m.
  11. Katie preston
    Az
    Yes thanks for the quick reply i just looked in YouTube looks easy enough but i’ll leave it to my husband:) the battery is original and the car is 8 years old so maybe it’s due for a replacement anyway??
  12. bisco
    49,353
    very likely. average life is around 5-6 years. more in cold climates and less in hot.
  13. Katie preston
    Az
    So i replaced the 12 v battery and the very next day the PCS warning light came on! I am at a loss...........
  14. bisco
    49,353
    sounds like it's back to the dealer, or someone who can read the codes.
    what is the static voltage of the new 12v?
  15. Katie preston
    Az
    No clue....i will get it checked and keep you posted the dealership is such a rip off! But...
  16. Kamil
    Kamil New Member
    Poland
    Hello Katie,
    Did you manage to fix the issue?
    I got 2011 Lexus CT200h and have the same behaviour...
  17. Cloude1
    Cloude1 Junior Member
    23
    Sydney NSW
    2010 Prius here. Happening to me now.
  18. ilovegirls
    ilovegirls Member
    173
    San Diego
    I had this happen to me last night. I disconnected the battery and left it overnight. This morning I woke up and reconnected the battery. The "check pcs" was still on.
    I pushed the pcs button on and off around 5 times and nothing.
    I turned off the car on and off around 5 times and still nothing.
    I drive the car down the street and the check "pcs" goes away but a little pcs light is on meaning the pcs system is off.
    I'm not sure what made it go away but that is what I did. Hope this helps.
  19. Mendel Leisk
    38,630
    For anyone else hornswaggled by the acronym:
    PCS equals Pre-Collision System
    Raytheeagle likes this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    As long as you don’t get bamboozled we should be fine:p.
    Always working on expanding our vocabulary (y).
    RachaelH likes this.
