Check PCS system
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Zuinat, Oct 30, 2016.
  1. Zuinat
    Zuinat New Member
    Jordan
    I
    Hello,
    I have an error says " check pcs system. I took the car to dealers but it seems they are guessing as they tell different reasons. I found the brake oil lower than it was but not sure if it could be the reason.
    I had it scanned and here's the result:
    ABS/VSC/TRC = FAULT
    Advanced parking guidance system = FAULT
    Prius 2010
    I attached a screenshot
    52,410
    welcome! did they say what the pcs system is?
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Sounds like the PreCollision System.
    How many miles? Have you got a code reader or know someone who does? Any work to the brakes recently?
    SFO likes this.
  4. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    bisco and Robert Holt like this.
  5. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    If it is the pre collision system, that would include the seatbelt pre-tensioners also, which might be another site for a bad electrical connection to occur.
    But the posted diagnostic codes in the computer would be helpful if you have a Techstream type of reader that will correctly interpret them.
    bisco and Raytheeagle like this.
  6. bisco
    52,410
    uh-oh, double posting again.:unsure:
    Raytheeagle likes this.
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Unfortunately:(. We've been having a good run though:whistle:.
  8. bisco
    52,410
    it was a very nice few weeks...
  9. Zuinat
    Zuinat New Member
    Jordan
    I
    #9 Zuinat, Oct 31, 2016
  10. bisco
    52,410
    the video didn't load. did you scan with a toyota specific scanner? also, you may want to try disconnecting the 12v negative for a few minutes, but you might want to scan codes first. the buzzing noise is probably the brake accumulator. has it gotten worse, or is it new altogether. mine buzzes when i open the drivers door, and now and then while driving.
    Robert Holt likes this.
  11. Zuinat
    Zuinat New Member
    Jordan
    I
    The site doesn't support the vid. Here's a picture instead. this thing in the picture always keeps buzzing and vibrating and yes I scanned it
  12. bisco
    52,410
    if the buzzing has increased, it may be leaking.
    Zuinat likes this.
  13. Mendel Leisk
    41,937
    Is this a sound you hear when opening the driver's door, buzzing that goes on for about 10 seconds? If so, that is normal; it's the brake system pressurizing.
  14. Zuinat
    Zuinat New Member
    Jordan
    I
    it's like the sound I hear when I open the door but it's constant and not sure if it comes from the ABS or something else. it comes from the thing indicated in the picture
  15. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Here in the states we had a recall for the brake booster. Did you get one in your neck of the woods?
    It sounds like the system is continually trying to pressurize but cannot. Sounds like blow by of the fluid or there might be air in the system.
    What is your brake pad thickness? Any work done recently on the brakes? Do you use a lot of regen braking or use the friction brakes? Have to use the brakes for an extended period of time where heat may have boiled the fluid, creating air in the system?
    SFO, cmyk_ed, Rebound and 2 others like this.
  16. Bassir
    Bassir New Member
    The Netherlands
    hello Zuinat,
    i have the same problem with my prius. Did you fix it ?
  17. Matth Torrijos
    Matth Torrijos Active Member
    114
    208
    Poway
  18. angelahortega
    angelahortega Junior Member
    29
    Ukiah
    I got this at 202,000 miles. Took it to the dealer after checking the battery, fuses and giving the car a wash to make sure the sensors were clean. Dealer had a Code C13194. notes show ABS PUMP/Cylinder is leaking. Online says leak in accumulator. End result $3700 to repair.
