Check Tire Pressure on new car...
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Photau, Jan 11, 2013.
  1. Photau
    Photau Junior Member
    46
    Mastic Beach Village
    I checked my tire pressure 4 days after getting the car from the dealer, fronts 28, rear 26psi. Not sure if it was for a soft ride on the test drive, or they just did not check it.
  2. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    If I recall, mine were about 2 psi below the recommended. I think they were 33 psi front and 31 psi rear. I am running 38 front and 36 rear now.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Many here go with 42 front and 40 rear for best MPG.
    If the ride's to harsh lower it a bit.
  4. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Could be they planned it that way, or maybe just didn't check before delivery to you. Figure from the time it left the factory and if it sat on the dealer's lot for a while, losing a couple of psi each month, you could easily be down that much from the recommended pressure. I keep mine at 40/38 for a compromise between ride and economy.
  5. grodnyc
    grodnyc Junior Member
    24
    Long Island, NY
    That happen to me too...it was in the 20s.
    Now I run 40 Front and 38 rear.
  6. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I go 42 all around, I don't notice and ride quality difference.
  7. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
  8. rogerv
    1,639
    317
    That seems to be an "inflated" price. :LOL: (Sorry, I just couldn't help myself.) Costco includes it with new tires, and gives free fills as needed to maintain them. I have a portable air tank for use in my garage, and sometimes the guys at Costco fill that from the nitrogen supply instead of the regular air hose. There have been lots of pros and cons discussed in other threads on PC. When the OEM tires on my PiP wear out, I plan to purchase replacements at Costco and then run the nitrogen, as I do in my Lexus. I tried to buy tires for my Miata there, but since it has aftermarket wheels, Costco won't mount tires on them. :(
  9. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    I go to Costco to air up and always use the Nitrogen pump. Its free and just sitting outside the garage. I use the one in Cypress, CA.
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    usbseawolf2000 and xs650 like this.
  11. CharlesH
    2,785
    1,152
    Roseville, CA
    Since 80% of the air we breath is nitrogen, it is not exactly a precious commodity. The process to make liquid nitrogen from air is straightforward and very inexpensive, and they just let it evaporate and put it in tanks. That is why Costco can just give it away. When I was in college, liquid nitrogen was used with the casualness of water.
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Plus, if O2 really leaks out as much faster as the N2 cult claims it does, a tire filled with air would end up filled with N2 over several months. Either a tire is an effective N2/O2 sieve or it isn't. If it is, there is no reason to use pure N2 because the O2 will all leak out leaving close to pure N2. If a tire isn't an effective molecular sieve, then there is also no reason to use N2.
    N2 is a good source of dry stuff to fill a tire with, so there is some small advantage if the alternative is filling your tires in a humid climate from a thankless compressor or a poorly maintained compressor with a tank.
    priuskitty and 3PriusMike like this.
