Check Your Bearings
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by auto parts addict, Mar 27, 2009.
  1. auto parts addict
    auto parts addict New Member
    CA
    If you want to check your bearings for wear without removing the wheels, do the following:
    1. Jack up your car and support it on safety stands. If you've been checking your brakes, your car is already jacked up.
    2. Grasp each wheel at the top and bottom and attempt to rock it. There should be minimal movement. Excessive play may indicate that wheel bearing is worn and needs adjustment or replacement.
    3. Put the gearshift in neutral if you have an automatic transmission, or take your manual transmission out of gear.
    4. Rotate the wheel, listening for any unusual noise and feeling for any roughness as you rotate the wheel. Any unusual noise or roughness may indicate that the bearing is damaged and needs to be replaced.
    5. Shift back into gear (for a manual transmission) or park (for an automatic transmission) before lowering the vehicle to the ground.
  2. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    That's the old-timey way to check for a bad wheel bearing, and it still works well
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Sorry for hijack but hey Jayman I see the floods are reaching Manitoba too. Are you anywhere near the Red?
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    We used accelerometers and an FFT to get a spectral response, but that might be overkill for a car.
    Tom
  5. jayman
    13,439
    640
    Winnipeg Manitoba
    Almost an hour east. I'm on relatively high ground, so no worries here. It will cause HUGE problems due to the sudden and massive Spring blizzard we had Wednesday and Thursday. Almost 2 ft of snow
    Folks only 20 km west of me are in deep s***. I mean that in a literal sense. The large hog and cattle barns use lagoons to hold the animal s***. Most of the lagoons are already overflowing
    So, when the flood waters reach the lagoons, folks will quite literally be up to their mammary glands in s***.
    Folks in ND are really screwed, I hope they come out of this relatively dry
  6. jayman
    13,439
    640
    Winnipeg Manitoba
    Just *mention* of a fast fourier transform and I get a hot flash all over ...
  7. richard schumacher
    7,663
    1,038
    United States
  8. jayman
    13,439
    640
    Winnipeg Manitoba
    Old timey isn't always the best way, certainly not the most accurate way. For old caged tapered bearings, it worked ok enough. Modern sealed ball bearings, not so well. The hub would have to be completely trashed before the "wiggle" test would work
  9. edthefox5
    10,096
    4,806
    Clearwater, Florida
    That what I was thinking there too Jayman. I think the hub would go up in flames if it had wiggle in it from bad bearings. See that down here all the time from idiots with there boat trailers where there wheel bearing's are so bad the wheel is wobbly...and smoking. In a car the noise would be really loud.
    The op's test was more a bad ball joint test actually.
    Flood: I thought of you when our local newspaper front page picture was from a bar on the Red River "Cats on the Red" in Manitoba from
    bar's patio with the river full of huge ice chunks and water almost to the patio.Don't look good.
  10. jayman
    13,439
    640
    Winnipeg Manitoba
    I'm ok where I am, high and dry. Just 18 miles west of me, a lot of flooded basements. Folks in places like Emerson and Morris, St Adolphe and St Agathe, are really worried
