Check your Cabin Air Filter Today!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by efusco, May 5, 2006.
  1. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    See This Thread over at PriusOnline. Besides, it's a good time to vacuum it out as the weather's warming up to make sure your AC is not running any harder than necessary so you can really see that nice summer Fuel Economy Boost.
    Coastaletech sells the replacement filters for $19 + S&H, that's about as cheap as I could find them. If someone knows how/where to get them cheaper please share.
    Also, John1701a has a very nice write up on how to find and replace. Probably more detail than most need, but if you're not very handy it may help.
    I checked mine today after seeing that thead. Had a few leaves and some other junk in there so I pulled out the shop vac and cleaned it up before sticking it back in. I figure it'll wait another 5k miles.
    Also, I always forget who, someone here has a nice Hepa filter he just cuts up to fit the spot and it works out to be much cheaper than getting the 'official' filter from Toyota. I haven't done that yet, but perhaps I should.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
  3. Muleears
    Muleears New Member
    22
    Windsor, VA
    <div class='quotetop'>QUOTE(efusco @ May 5 2006, 10:22 AM) [snapback]250187[/snapback]</div>
    A stupid question from a newbie. Does the classic have the AC filter, if so is it in the same place?
  4. tochatihu
    tochatihu Senior Member
    9,852
    3,814
    Kunming Yunnan China
    2001 Prius
    The "washable electrostatic" filters sold for whole house HVAC are not HEPA, but they seem comparable in effectiveness to the Toyota original. Purchase at hardware store of your choice (about $20), liberate the treated foam material from its frame, and cut into as many 21.5 cm squares as possible. Rinse and dry it at your interval of choice.
    I don't expect that one of these squares is a lifetime supply because the magic electrostatic treatment must eventually wear off. But you will be extending your replacement intervals very far.
    Also, there is a Canadian source for actual HEPA car filters, but I will need some help remembering the name.
  5. ghostofjk
    ghostofjk New Member
    979
    This may sound a little odd, but I'd suggest to the powers that be that a sticky be posted atop the Maintenance Forum reminding people to do this. Not only is it easy to forget if you're DIY person, but I've already had the experience that the dealer also overlooks it when doing one of the bigger maintenance services.
    And yes, Muleears, it's in the same place on the Classic Prius. And it's not a stupid question.
    2010_Prius_I_White likes this.
  6. Tideland Prius
    16,621
    Canadian Tire sells MicronAir particular filters for Cdn$20++
  7. tmorrowus
    tmorrowus Member
    514
    <div class='quotetop'>QUOTE(efusco @ May 5 2006, 09:22 AM) [snapback]250187[/snapback]</div>
    I paid $19.38 (no shipping) from my dealer's parts desk, after the 10% parts discount that most dealers will give if you ask or have coupons.
    <div class='quotetop'>QUOTE(seasalsa @ May 5 2006, 09:42 AM) [snapback]250201[/snapback]</div>
    When I got my Cabin filter from the dealer it came in a red cardboard box with "toyota original parts" all over it. Since I don't see that box in the ebay photo I'd be concerned that it may not be as high quality as the original part.
  8. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(tmorrowus @ May 6 2006, 02:58 PM) [snapback]250804[/snapback]</div>
    I agree that that does not look like it's and OEM part on the Ebay item, but I also have to say that I seriously doubt it makes a lick of difference. I do want the larger portion of the pollen, leaves, mouse poop, etc. filtered before it hits the cabin, but I'm skeptical of the effectiveness of a HEPA filter in the environmental conditions of a car. To be honest I have a feeling a coffee filter cut to shape might be just about as effective though the pleats probably help increase the surface area to improve air flow and to catch the bad junk as it goes through.
  9. tmorrowus
    tmorrowus Member
    514
    <div class='quotetop'>QUOTE(efusco @ May 6 2006, 03:28 PM) [snapback]250812[/snapback]</div>
    efusco I'm sure you know all this, but...
    You can't tell a good filter by just looking at it... there are two main parameters that are important: What is the smallest particle size that it filters out, and how much does it impede airflow. Optimizing both of those parameters is not easy, and I would trust Toyota to have done the R&D to get it right. After all, if the filters impede the airflow, they will get burned out fan motors that they have to replace under warranty (or have to overdesign the fan motors at great expense to compensate for a poor filter). If the filters don't filter small particles they won't qualify for HEPA designation. But aftermarket filter manufacturers don't have any of those requirements, they just have to look like they are the same size. I notice the ebay page doesn't use the word HEPA.
    A bad filter will "work" but will either increase the load on your HVAC system (reducing it's effectiveness at extreme temperatures), or will fail to filter as well. It seems to me that paying an extra $10 every few years for the OEM part is worthwhile.
    Okinawa, prius8654 and Susanne101 like this.
  10. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(efusco @ May 5 2006, 07:22 AM) [snapback]250187[/snapback]</div>
    Good reminder as I live in the San Joaquin Valley and we are always in competition with LA and Riverside for poorest air quality in the nation. I did a search of priuschat for HEPA and this is what I came up with.
    http://priuschat.com/index.php?showtopic=1...=0&#entry182839
    Wildkow
  11. efusco
    19,891
    1,196
    Nixa, MO
    <div class='quotetop'>QUOTE(tmorrowus @ May 6 2006, 03:45 PM) [snapback]250820[/snapback]</div>
    Excellent points all...I think I really didn't consider the extra potential strain on the system that might occur. I'm less concerned about the 'quality of filtration' as I think there are so many other sources of contamination within the car that it matters little what kind of filter it is. But I could be totally wrong on that account too. So I conceed it probably does make good sense to spend the extra $10.
  12. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    if you're like me any possible extra filtration would be completely gone when you drive around with the windows open all day anyway :lol:
    my car's interior gets covered in pollen grains every time i go out for a drive. good thing i'm not allergic to that kind of stuff.
  13. seasalsa
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(tmorrowus @ May 6 2006, 12:58 PM) [snapback]250804[/snapback]</div>
    Mine came in a Toyota original parts box. Notice that they have the Toyota parts number on them in the photo. I notice Toyota dealers sell on eBay, check out the oil filters from Rusty Wallace Toyota.
  14. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have allergies. They hit bad twice a year. Spring with the tree pollen and fall when it starts raining with the mold. My friend the allergist suggested changing the air filter more often than recommended and it has made a noticeable difference. If you have allergies change it.
  15. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Guilty as charged.
    Actually, it isn't a true HEPA-rated filter, but very close. It's the Supreme furnace filter from Canadian Tire, which is rated at MERV 12. Usually, a HEPA is rated at MERV 16+, which is something you probably have in the OR.
    I first got the idea when I had my house in the burbs. My HRV was sucking in dust, pollen, etc, and the standard foam "filter" didn't cut it. It was very easy to take a Canadian Tire Supreme filter, trim to fit, and it made a huge difference to my indoor air quality. I ran the HRV 24/7 and never noticed any difference in the fan temperature.
    What I DID notice was the crap the filter collected out of the incoming air. In winter, I could usually get the filter to last the entire season. In summer 2 months max and it was BLACK. Geez, hope I don't catch lung cancer walking around outside.
    The couple I sold the home to remain in touch with me, and based on my recommendation they also use Canadian Tire Supreme furnace filters in the HRV. That HRV is almost 6 years old, and still going strong.
    I haven't noticed any difference in airflow using a Canadian Tire Supreme filter. It works out to about $10 Cdn as I can get 2 Prius HVAC filters out of one Canadian Tire filter.
  16. dancekat59
    dancekat59 Member
    244
    uh... I've searched this forum and can't find the answer to...
    regarding the cabin air filter, is cabin air entering through the vents filtered ONLY when using A/C or is all air entering the cabin through the vents filtered??? :unsure:
  17. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    <div class='quotetop'>QUOTE(dancekat59 @ May 28 2006, 11:15 PM) [snapback]262291[/snapback]</div>
    I think its for all air, but I'm not sure.....
    I was wondering Evan, how many miles to you estimate it takes before they need cleaning?
  18. Metro
    Metro Your OEM Q & A Resource
    76
    Cleveland, OH
    <div class='quotetop'>QUOTE(windstrings @ Jun 12 2006, 11:32 PM) [snapback]270344[/snapback]</div>
    If anyone is still interested I sell them for $15.00 plus shipping through my website. They are Genuine Toyota filters.
    Recommended inspection/cleaning/replacement is every 15K. Earlier if you can remember would be better since some of the ones that I have seen have been pretty bad even though they were not overdue for service.
  19. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    Did we ever determine that the cheaper ones are just as good as the more-expensive electrostatic kind (like I bought)?
    While it'll be a bit before my next replacement, this reminds me to look for more junk on it like I found last time...
  20. MiamiPrius
    MiamiPrius New Member
    Miami, FL
    https://www.autohausaz.com/
    I found a super cheap place for filters...Engine air filter and cabin air filters. Engine air filters are $10.45 and Cabin Air Filters are $6.05 They fit better than the factory. Cabin air filter part number
    MAZ074446 White Box (dont let teh Mazda part number fool you it pits perfect...no cutting or alterations...at least not for my 2005 Prius). And their engine filter part number TOY089329. And if you order over $50 in stuff shipping was free. So I stocked up. I was a little worried about the fit... but no worries they were great.
    :D Just had to let everyone know.
