Checking 12v battery from headunit (video)
Discussion in 'Gen 3 Prius Main Forum' started by abubin, Aug 19, 2020.
  1. abubin
    abubin Member
    182
    91
    Malaysia
    Here is a simple and quick video on self checking the 12v battery for those who have a headunit.
  2. ASRDogman
    ASRDogman Senior Member
    6,061
    3,253
    12.2v is not okay. It's low.
    That sure looks strange with the steering wheel on the right hand side! :)
  3. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    That’s because the proper way to measure is from the jump points under the hood without a load. The method above will cause everyone to hit the panic button and replace their 12 v bat.
  4. ASRDogman
    6,061
    3,253
    I guess... I seem to recall someone said reading it that way it will always be lower.
    It seems easier to just pop the hood and put a meter on it. It would be faster! :)
    Grit likes this.
  5. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    Some people don’t even have “time” to open the hood to check their oil level, what are the chances of them finding their multi meter, opening the fuse box and tap on the jump points? And the do the reverse once done? That’s some valuable Netflix time man :ROFLMAO:
    #5 Grit, Aug 19, 2020
    ASRDogman likes this.
  6. abubin
    abubin Member
    182
    91
    Malaysia
    12.2v is fine. Not great but good enough that you don't need to start looking for replacement. Correct me if I am wrong, I think the 12v battery is not needed for starting the engine. The HV battery take cares of it once that car is in READY mode. Would love to get my hand on a faulty battery that won't start the car so that I can measure to voltage to see what is a dead voltage level.
  7. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    Pull the 12v lead off the battery and try to put the car on ready. Let us know what happens.
  8. ChapmanF
    15,456
    Yeah, in every Prius where I've checked, it has been lower by, like, 0.6 or 0.7 V ... but not changing very much for a particular car, so noticing the difference once and just doing some quick mental arithmetic later isn't much trouble.
    That means if I ever went out some morning and read my car at 12.2 on the MFD, I would be camped out at night trying to see who's been sneaking around and charging my battery. (It better not be the same clown who keeps leaving the zucchini in the back.)
    #8 ChapmanF, Aug 20, 2020
  9. abubin
    abubin Member
    182
    91
    Malaysia
    Just made a quick check using multimeter.
    multimeter: 12.38
    headunit: 12.1
    Knowing this mean, we can quickly do a calculation when measure using the headunit. For tmes when we are on the road or not having a multimeter available. This is good enough for some reference.
    Thanks for sharing. As always great community here.
  10. Salamander_King
    Salamander_King Senior Member
    10,970
    8,853
    New England
    I use a BlueTooth battery monitor II permanently installed on the 12v battery posts in my Prius Prime. With Covid-19 restriction, I am not driving my car much. I could pop the hood and check the 12v battery with a DMM, but with this device, I get daily notification and 24/7/365 monitoring from the comfort of sitting on a couch. I don't let my 12v battery go below 12.4v. I charge promptly with a smart charger when my phone notifies me.
    davecook89t and NewHybridOwner like this.
  11. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    For others who might be interested in getting one, what is the make and model of the particular device you are using?
  12. Salamander_King
    10,970
    8,853
    New England
    QUICKLINKS Bluetooth 4.0 Battery Monitor II
    Bought the first one ~$30 on Amazon that I am using on PRIME, and bought another one ~$18 from AliExpress I am using on another car. There are few other models and makes available that does the same thing.
    The accuracy is within 0.05V compared to Fluke DMM. It reads the voltage of 12v battery every 2 min and store the data inside for 30 days. But the data can be synced to phone App as many times as you want and if you sync at least once every 30 days, the data will be stored in the phone app indefinitely. It is very convenient to be able to check when I last charged the 12v and how low or high it was while I am driving or working on the car.
    #12 Salamander_King, Aug 20, 2020
    davecook89t likes this.
  13. Johnny Cakes
    Johnny Cakes Senior Member
    1,010
    761
    Virginia, USA
    Abubin, you are correct. The traction battery supplies voltage to "crank" the engine.
  14. ChapmanF
    15,456
    Grit was being tricksy there. Although the 12 volt battery is not used to start the engine, it is the car's only source of power until it is made READY, which means you won't be able to READY the car if the 12 volt battery is disconnected ... an impeccably true statement, though a little bit sideways from what abubin was asking.
    If you get the car into READY mode and then unhook the 12 volt battery, the car will stay in READY mode, stopping and cranking the engine as often as it likes. (Of course if you push the off button in that condition, everything will go dark a lot more instantly than you're used to.)
