Checking 12v voltages, Under hood ?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dorf, Jan 24, 2010.
  1. dorf
    dorf Member
    132
    Little Rock
    Could someone please re-post the 12 volt battery voltage ranges when checking under the hood with a voltmeter. I can't seem to locate them.
    (Should have printed 'em ) I checked my '07 after sitting for a day it registered 12.44 V-Good -Bad- or Normal ???
    Thanks !!!
  2. Patrick Wong
    18,210
    6,513
    I assume the car was IG-OFF when you measured 12.44V. This means that your battery is around 50% charged.
    A new AGM battery, fully charged, should measure ~12.9V. 12.1V is discharged.
  3. direstraits71
    direstraits71 Member
    367
    65
    Central Coast California
    Your numbers seem a bit high. Does an AGM battery read differently (higher?) than a flooded lead acid battery? I found lower numbers for state of charge for flooded cells here:
    Charging the lead-acid battery
  4. Patrick Wong
    18,210
    6,513
    Yes, an AGM battery should produce a slightly higher voltage for a given charge state:
    "The sealed AGM and Gel-Cell battery voltage (full charged) will be slightly higher in the 12.8 to 12.9 ranges."
    Battery Basics: A Layman's Guide to How Batteries Work | BatteryStuff.com
    I recently bought a replacement Toyota 12V battery (same as original equipment) for my 2004, and it measured 12.9V out of the box.
  5. direstraits71
    367
    65
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    The big Gel-Cell battery on my boat reads just over 13 volts after being fully charged. With any use it quickly settles to 12.9. The charging is being done by a $2,000 computer controlled charger/inverter programmed for the battery type. The battery has been in use for a decade and is still going strong.
    Tom
