Checking Auxillary Battery for 2014 Prius.
Discussion in 'Newbie Forum' started by frankenstein, May 6, 2017.
  1. frankenstein
    frankenstein Junior Member
    17
    Can anyone tell me the procedure for checking the 12V auxillary battery in 2014 Prius? Thanks.
    49,504
    after the car has been off for a few hours, pop the hood, and put a volt meter on the jump point inside the fuse box.
    should read 12.4 or better. 12.0-12.3 is iffy, less than 12 is bad. you can try charging it, and see how it holds, before replacing.
    a new, fully charged 12 volt reads around 13 volts.
    my 5 year old battery reads 12.56 volts.
    Peter Baylie and RCO like this.
