Checking motor mount before replacing...
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by blinkwatt, Nov 14, 2023.
  1. blinkwatt
    blinkwatt Junior Member
    Sacramento, California
    Is there anyway to tell if a mount is bad short of pulling it and checking for play?
    More specifically, the passenger side mount by the coolant reservoir.
  2. Tombukt2
    Tombukt2 Senior Member
    13,143
    2,361
    Durham NC
    Usually you can get a long bar like an iron digging bar and you can get that wedged in somewhere and rock the engine around and if you can make it clunk or clank then it's a good bet that the one of them is got shot rubber if you have an oil leak that's running down and anything like that that's soaked one of the mounts that can damage the rubber generally it's been my finding so far that it's quite rare so check carefully or you'll just be replacing mount or mounts for the heck of it they get soft over time but unless they're getting something on them a lot to deteriorates the rubber they generally hold up to the 250,300,000 plus mile mark.
