Checking Nav Version?
Discussion in 'Gen 3 Prius Audio and Electronics' started by RockerC, Aug 29, 2013.
  1. RockerC
    RockerC Junior Member
    39
    23
    I bought my pre-owned 2011 Prius 4 from a non-Toyota dealer, and they did not have the original Nav disc at the time, so put in another that they had there. Many roads are non-existent on the maps, and I wonder how I can check which version I have? I have seen that the 2013 update should be out around october, any ideas exactly when?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    A Toyota dealer should be able to tell you.
    To check version press Setup button -> then Map. I believe this will display Nav version info.
  3. RaZa
    RaZa Member
    480
    93
    or you could spend less than half as much and get a much better dash mounted gps and enjoy the benefits of being able to take it with you anywhere as well as free map upgrades for the life of the unit...
  4. jdcollins5
    5,131
    1,338
    Wilmington, NC
    I prefer the benefits of the built-in Nav. Yes, the cost of updates are high but I have only seen the advantage of updating every 4-5 years.
