Checking Oil Level
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JC91006, Dec 16, 2013.
  1. JC91006
    16,672
    8,518
    I know this may seem like a really dumb question, but I was checking the oil on my 2008 prius today and noticed I get different readings on the front and reverse side of the dipstick. One side I have a halfway mark between the 2 marks, flip it over to the backside and I see my oil level is full. So I'm not really sure what the correct reading is. Anybody else notice this when checking their oil level? So anyone with insight to this dumb questions, please ring in. Thank you very much for your help.
  2. Patrick Wong
    18,200
    6,492
    Yes, your observation is normal and this is not a dumb question. Use the lower dipstick reading as the correct one. Your oil is around 0.8 US quarts low if the oil level is at the halfway point.
  3. jdenenberg
    jdenenberg EE Professor
    3,926
    1,923
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The lower of the two readings is the correct one. The higher reading is due to residual oil in the dipstick tube.
    JeffD
  4. JC91006
    16,672
    8,518
    Thanks Patrick for the insight. I never noticed any oil burning before but lately I've read many threads on oil burning, thought I would check. I also just changed to a 0-20 synthetic 3000 miles ago and I probably will go back to my 5w-30 blend. The change might not be agreeable with my engine. I currently have 126000 miles on the engine.
  5. JC91006
    16,672
    8,518
    I figured that would be the case, just wanted to confirm with you guys to make sure. I don't want to add oil if I'm not really low. Thank you.
  6. Patrick Wong
    18,200
    6,492
    Again, I agree with your observation. When I lived in southern Orange County, I tried Toyota 0W-20 and found that my 2004 started to consume oil. So I went back to 5W-30 synthetic and the oil consumption continued, although at a reduced pace.
    Now with 163K miles, the 2004 is consuming around 1.3 quarts per 5K miles, which is not the end of the world.
  7. uart
    uart Senior Member
    4,220
    1,209
    Australia
    It's normal to get slightly different readings, but your discrepancy seems larger than normal. Make sure you remove the dipstick and wipe it first, then re-insert to take a reading. For me this really seems to minimize the error. Normally the discrepancy shouldn't be more than about a quarter of the L to F distance.
  8. Patrick Wong
    18,200
    6,492
    I think that the discrepancy increases as the oil level drops. If the oil level is at the top dimple, both sides of the dipstick will read about the same level.
  9. Mike500
    Mike500 Senior Member
    2,593
    766
    It is that one edge of the dipstick makes very close contact with the dipstick tube that there is a "capillary action effect" which draws the oil up the dipstick above the real oil level in the pan.
  10. JC91006
    16,672
    8,518
    I've checked my oil many times on other cars, this seems to be the only time I notice there's a difference when you flip over the dipstick. At times, when I can't get a good reading on one side, I would simply flip it over to get a better reading. This time however, I got 2 separate readings that were quite far apart. Like I mentioned before, I never noticed this before because my engine never used any oil before I switched to the 0w-20 on my last oil change.
  11. JC91006
    16,672
    8,518
    Do you use the high mileage formula 5w-30 on your car? Strange the engine started using oil after 0w-20 and can't reverse course after you go back to 5w-30 weight.
  12. ETC(SS)
    6,953
    The only dumb question is the one that you do not ask.
    There are many MANY opinions on viscosity, intervals, etc.
    The 2 most important things are to ensure that there is oil in the crankcase in the correct operating range, and that this oil has been changed sometime within the periodicity recommended by the OEM.
    Period.
    That's It.
    That's ALL.
    Using one viscosity over another (provided that you're within the blends recommended by the OEM) or legging your change interval out to 10K from 5K should not make a significant difference in your motor wear provided that you regularly check your oil and regularly change your oil.
    Usually???
    People "discover" that their baby is "suddenly" using oil after years of not checking their dipsticks, and not determining how much oil was drained out of the engine during infrequent oil changes.
    Me?
    If I were an owner instead of just a driver, I'd use 5w30 every 5K.
    If I lived in the frozen North?
    It would be different.
    If I were a suburbanite?
    It might be different.
    Your car.
    Your call.
    Good Luck!
    MERRY CHRISTMAS!
  13. Patrick Wong
    18,200
    6,492
    No, regular full-synthetic 5W-30, such as Mobil 1, Valvoline, whatever name brand Walmart happens to have on sale.
  14. JC91006
    16,672
    8,518
    What's your take on the high mileage formulas? I know they are designed to swell up the gaskets and what have you to reduce oil usage. Will this type of oil have any negative effect on the car?
  15. Patrick Wong
    18,200
    6,492
    I haven't tried to use a high-mileage oil formula so I don't know whether it actually provides any benefit or is just marketing hype.
  16. uart
    uart Senior Member
    4,220
    1,209
    Australia
    But can you confirm whether you wipe the dipstick before checking. Personally I've never gotten a very accurate reading on the dipstick unless I wipe it first.
  17. JC91006
    16,672
    8,518
    Yes I've wiped it every time I pull it out and check. I couldn't understand why the mark would show a higher reading in the backside of the dipstick. There is a bend on the dipstick tube you insert the dipstick into. That approximately 70 degree bend, if the dipstick were to rub while you pull the dipstick out, would leave a mark on the other "lower" range of the reading. The reading I get is higher as if I got the reading from inserting a dipstick that I didn't wipe down and spread out on the bend.
  18. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    All of the high mileage oil are just marketing hype, even if they claim they put in additives to soften the o-rings, it still won't help with piston ring wear.
    My experience is once the o-ring is hardened, no chemical can restore it to the original compliance.
  19. uart
    uart Senior Member
    4,220
    1,209
    Australia
    Rude person's gave a very believable explanation above: that the dip stick sits very close to the tube on one side, which causes capillary action to drag the oil level upward slightly.
  20. JC91006
    16,672
    8,518
    would this action of pulling out the dipstick cause the oil to rub/drag downward on the dipstick, which should provide a lower reading vs a higher reading?
