Checking on starting only 2012 Prius v
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Tarek, Jul 19, 2024 at 11:22 AM.
  1. Tarek
    Tarek Junior Member
    Tx
    Hello everyone I hope all doing good
    one day Is tarted to head radial cheaking on my motor prius v 2012 215K Miles. so basicly when i started started to check than once i press gas on parking gear it goes away.
    points to notice: when i run with the car and park for small perioud of time and start again doesn't do it. only when the car parked few good hours or of course a new day.
    only I read code it was miss fire on 2 and 4 :
    Cylinder 2 Misfire Detected
    Code P0302 indicates that Cylinder 2 had too many misfires within a predetermined period of time.
    Secondary DTCs
    P0300
    Р0304
    P0101
    Р0302
    Р0300
    Р0304
    Random/Multiple Cylinder Misfire Detected
    Cylinder 4 Misfire Detected
    Mass Or Volume Air Flow Circuit
    Range/Performance
    Can anyone help me
    I decided to take and clean following:
    1- clean Intake minifold (clean the current one)
    2- clean EGR valve cooler (clean the current one)
    3- new sparks plugs
    4- clean fuel injectors ( new o ring and gaskets)
    5- pvc valve new (new)
    6- clean the throttle body only with the cleaner
    after all the car running a lot smother than before of course yes
    BUT the checking came back again after one day.
    I would appreciate any help
    I love this car Pius V is very nice one
    #1 Tarek, Jul 19, 2024 at 11:22 AM
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,970
    4,712
    Texas Hill Country
    If you have a really rough start with shaking and a severe rattling, plus it goes away and runs smooth for the rest of the day, it is very likely a leaking head gasket. Very common.
    It does not present in a traditional way on a hybrid.
    Shudder video (coolant loss and holes in the block are an advanced stage)
    A more definitive test
    Car Care Nut HG Borescope at 7:40
    #2 rjparker, Jul 20, 2024 at 3:26 PM
    Brian1954 likes this.
