Checking quality of coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Caleb302105, Mar 10, 2015.
  1. Caleb302105
    Caleb302105 Junior Member
    29
    Bend, OR
    Hello, I'm wondering if there is anyway to test the effectiveness or quality of the engine or inverter coolant. I can't seem to find anything online for testing Toyota SLLC.
    Thanks for your help.
  2. JC91006
    16,496
    8,406
    It's a safe bet to change it out based on mileage. 100k miles and then every 50k afterwards. This is in the owners manual
  3. Caleb302105
    29
    Bend, OR
    I was able to pull my service history and found that the inverter coolant had been changed at 60,000 miles in 2012 due to a recall with the inverter coolant pump. The car is now at 90,000 miles. I'll assume that based upon that information I will be able to wait a bit longer before having it replaced.
    I already replaced the ICE coolant when I had to do the coolant storage tank control valve replacement.
    I appreciate your time and thoughts on this matter. :)
  4. RobertK
    RobertK Member
    128
    40
    Norfolk, VA
    Don't assume that the inverter coolant was changed when the inverter pump was replaced, even if the documentation says it happened. The procedure calls for replacement of the fluid, but it is quicker to clamp off the hoses, change the pump, and top off the system. Most dealer mechanics will do whatever is quickest, since they are being paid a flat rate per job.
    My inverter pump was replaced, and I'll change the coolant at 100K miles.
  5. Caleb302105
    29
    Bend, OR
    Alright,
    Thank you.
    I'll keep an eye on it. ;)
  6. bisco
    49,731
    consider your ice water pump and serpentine belt when you change the ice coolant.
