Checking status/maintenance hybrid battery
Discussion in 'Gen 2 Prius Main Forum' started by sanlen, Sep 8, 2014.
  1. sanlen
    sanlen Junior Member
    42
    Phnom Penh
    My 2007 Prius has been with me for 3 months now. I am really happy with its performance, especially its fuel consumption rate.
    I would like to check the state of the hybrid battery and maintenance it if necessary.
    Kindly advise how could i get this done?
    Regards,
    sanlen
  2. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If you have scangauge or other device that can check delta SOC check it. If its 16.6% or above battery can break anytime. If its more than 6.6% you should balance battery immediately. If your battery has high mileage then it might be good idea to balance it anyway at least if delta SOC isn’t 0.0%. You may want to drive while (you or somebody else is) observing the numbers and take highest reading.
    Only battery maintenance that you can do is to balance battery by slowly overcharging it. Traction Battery Preventative Maintenance - Hybrid Automotive Chargers | PriusChat or you can even build your own.
    Balancing battery pack cases wear to it (but not as much as driving with it imbalanced). So you shouldn’t do this too often.
    #2 valde3, Sep 8, 2014
  3. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Check the battery case, cooling fan, and ducts for dirt, and clean if needed. You never know what might be there in a used vehicle. Good info here and on youtube. For detailed battery diagnosis, the mini VCI is the best choice.
  4. krmcg
    2,592
    2,390
    Whittier, CA
    What are the specific steps necessary to check SOC when a scangauge is available?
  5. valde3
    2,002
    745
    Finland
    No you need delta SOC and not normal SOC. Connect scangauge and put in correct xgauge. No need for additional devices.
  6. krmcg
    2,592
    2,390
    Whittier, CA
    What is correct Xgauge?
  7. bisco
    49,610
    how many miles on her?
  8. krmcg
    2,592
    2,390
    Whittier, CA
  9. valde3
    2,002
    745
    Finland
