Featured Cheep Gas, Less than electric Power?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by hill, Oct 7, 2016.
  1. hill
    8,158
    Hard to believe - but this site says it's so - regardless of your state.
    Driving on Electricity Is Cheaper Than Gas in All 50 States | Plugless Power
    They do concede a bit for "high efficiency" cars - but don't specifically referred to the Prius
  2. El Dobro
    El Dobro A Member
    6,978
    3,213
    Now that NJ is raising the fuel tax 23 cents, the difference will be looking better.
  3. bwilson4web
    15,513
    A big part is fuel taxes both State and Federal but it also turns out the 2016 Prius, Level 2 ECO without fuel taxes is within 80-90% of the cost per mile as our BMW i3-REx. In effect, the high thermodynamic efficiency of the Prius engine and optimized control laws makes up for the transmission losses of the local grid and burning cheap coal.
    Now I've verified Prius driving techniques also work with the BMW i3-REx. So if I want, I could easily reduce my electrical costs 10-15% by driving it like a Prius (or Prius Prime.) But the 'free' electricity, about 1/3d of my kWhr, totally buggers efficient driving. The only frontier remaining is highway driving.
    Later,
    kgall and RCO like this.
  4. horent135
    horent135 Junior Member
    44
    CA
    2014 Prius Plug-in
    They need to do a comparison cost with public chargers vs gas. Public chargers in CA cost around 50-60 cent per kWh which might cost more than gas
    kgall, RCO and bwilson4web like this.
  5. bwilson4web
    15,513
    Exactly! You have to use local rates and availability AND remember we are not uniform within our local EV range.
    RCO likes this.
  6. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    States continually add taxes onto gas prices to fund road maintenance. I can see if fuel becomes less consumed, states will find somewhere else to get their money.
  7. Trollbait
    11,511
    That actually got through?
  8. El Dobro
    El Dobro A Member
    6,978
    3,213
    Just waiting for Christie to sign it and he's going to.
  9. bisco
    49,392
    unfortunately, the map is wrong. but hey, if deliberately misleading people can get them into ev's, it's all good, right?
  10. Zythryn
    Zythryn Senior Member
    6,235
    4,231
    No, it isn't. There are so many good reasons to drive electric I see no reason for "deliberately misleading people".
    However, saying the map is wrong without saying why can also be misleading.
    Care to elaborate?
  11. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    nuff said
  12. hill
    8,158
    yes - Cali public charging is all over the map.
    Some are free use ... some costs are fixed per kWh - some are fixed use per hour. Per hour costs are ripoff using a 3kw charger, but they can be a bargain if your charger is running 6 or 10kW's if the charger runs at the more powerfull levels.
    The article mentions residential "tier3" power can easily top 40ยข /kwh - but fails to elaborate on the convoluted high power 400v DC charging schemes. Again, you can find everything from free ones all the way up to nearly $4/kwh.
    Not only is that a mixed bag, gas costs can run from $2 to $4 gallon. That's gotta make pulling averages a tough row to hoe as the farmer would say.
    #12 hill, Oct 8, 2016
  13. RCO
    RCO Senior Member
    3,709
    5,183
    Cornwall
    All of UK is like that.... only worse!
  14. Trollbait
    11,511
    How is it wrong?
    It is showing the cash savings of driving an average electric car to an average ICE car(hint: not a Prius).
    Mass. has the lowest savings, and it is in the articles 10 worse list. The 19.1 cents per kWh quoted on the table is lower than what you pay, but it is a state average.
  15. bisco
    49,392
    headline says it all, not it isn't. most people aren't going to dive into the minute to find out it isn't, what kind of gas car qualifies or doesn't qualify for their statement, or what kind of ev would compare in comfort features and price to their current car, or cars they are looking at.
    that's deliberately misleading.
  16. Zythryn
    6,235
    4,231
    I don't think I've ever read any article in which all the details are laid out in the title.
    However, would "Driving on electricity, in the average electric vehicle, is cheaper than driving the average gas vehicle, for the average cost of electricity in all 50 states" be better?
  17. bisco
    49,392
    it could just as easily, 'driving on gas is cheaper than electricity in all 50 states'.
  18. Trollbait
    11,511
    Which many already believe because of "EV cost more than gas cars in fuel" studies that compare a Leaf to a Prius
  19. bwilson4web
    15,513
    One might do their own model using national and regional data from: U.S. Energy Information Administration (EIA)
    One could also use www.fueleconomy.gov which has a savings per vehicle. Put your vehicle in as well as alternates that you might consider buying:
    (NOTE: the image rotation is in the server. Open in a separate window to see the correct orientation.)
    I won't be doing a national model because I've already measured it locally:
    • $0.25 / 10 miles - BMW i3 electric, Huntsville AL $0.10/kWh
    • $0.37 / 10 miles - Prius gas, Huntsville AL $1.80/gal (Regular)
    • $0.60 / 10 miles - BMW i3 gas, Huntsville AL $2.00/gal (Plus)
    #19 bwilson4web, Oct 9, 2016
    RCO likes this.
  20. Zythryn
    6,235
    4,231
    No, that would be even less accurate.
    It would be true in some extreme cases, but not the majority.
    All the information in an article is not available in the title.
    Reading the body of the article gives a good layout of the spread of costs.
