chemistry question
Discussion in 'Fred's House of Pancakes' started by fortheanimals, Oct 19, 2010.
  1. fortheanimals
    fortheanimals Junior Member
    87
    portland, or
    ... or at least i think it falls under chemistry.
    what is the scientific term for the continuous even dispersion of oxygen in the air?
    say, so that we don't have to inhale from another direction once we exhale in one?
  2. Blizzard10
    Blizzard10 New Member
    168
    38
    Queens, NYC
    I give up... what is it called?
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  4. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    diffusion
    2 people like this.
  5. dogfriend
    7,512
    1,190
    Carmichael, CA
    [ame=http://en.wikipedia.org/wiki/Diffusion]Diffusion - Wikipedia, the free encyclopedia[/ame]
  6. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    biology is chemistry. chemistry is physics. physics is math. eventually you give up on what to call it.
  7. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    2 people like this.
  8. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I was wondering if someone was gonna post that, stev0 :)
  9. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    You can inhale and exhale in the same direction due to convective mixing.
  10. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Not chemistry, but are you thinking of the Ventouri effect ?
  11. Politburo
    Politburo Active Member
    971
    208
    You can inhale and exhale in the same direction because the body doesn't actually use all that much oxygen, combined with the effects of diffusion and convective mixing mentioned above.
    Exhale still contains ~16% oxygen, which is why you can give mouth-to-mouth, or breathe into a bag for some time before feeling ill. If you inhale an atmosphere with very low oxygen (<5% or so), you'll pass out in seconds. This is seen in industrial accidents where workers enter a vessel full of nitrogen.
  12. eagle33199
    5,122
    268
    2015 Prius v wagon
    And for those who don't know... the general atmosphere is made up of approximately 21% oxygen So each breath uses about 25% of the oxygen available in that breath.
