Chevy Volt Tidbit
Discussion in 'Chevrolet Volt' started by adrianblack, Aug 24, 2010.
  1. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Sorry this post isn't about the Toyota PHV, but I figured you guys might find it interesting none the less:
    For one, in addition to Eco, Normal and Sport modes, the Volt will have what's called Mountain Mode that allows it to climb any grade in the country. A GM engineer says they checked to be sure its Mountain Mode was adequate for any grade in the States and we have proof of at least one major mountain the Volt can climb. When Mountain Mode is selected, ideally about ten miles out from any big hills you want to climb, the Volt will kick on its on-board generator and create extra energy for the batteries. This allows the Volt's drive system to draw more power than normal from the battery packs while climbing a grade. If the battery packs are drained and the generator's already on, Mountain Mode will then increase the engine's RPM to make up the difference.
    Bradley also performed an impromptu 0-60 miles per hour test in the Volt, completing the run to highway speeds in 8.53 seconds while the car was in Sport mode. Not earth shatteringly quick, but plenty spry to feel normal in everyday driving conditions. Over the course of the day, Bradley drove the Volt a total of 59.7 miles, 16.1 of which occurred with the gas-powered range-extending on. During that time, 0.59 gallons of gas were consumed, which means the Volt achieved about 100 mpg for the day and 27.3 mpg while the engine was operating.
    The rest of the video is full of Volt information of which we're already aware, including how it interacts with mobile devices, charging options and the like, though we can't say we've seen anybody throw around the Volt yet like Bradley did.
    The link to the article / video
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    I wondered how many times that would be incorrectly published.
    It was 8:53. Notice that clock in the video only goes to up 59, not 99. So the time was actually 8.89 seconds.
    This is another great example of how GM is directing our attention away from the much asked, yet still unanswered question of Volt efficiency in CS-mode.
  3. kuhne
    kuhne New Member
    37
    Mexico
    The volt is a great car and I can't wait to check it out but it's MPG rating once the battery is depleeted is rather dissapointing
  4. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    Yep.... Also one commenter on the original post said he timed the video with a stopwatch and he got over 10 seconds for 0-60 ... so who knows what is happening in the video and with that crazy clock.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    The price, CS MPG and highway passing are the most dissapointing. Premium gas requirement and not qualifying for AT-PZEV and missing out on the HOV lane in CA are more dissapointments.
    If it runs on battery for the first 40 miles, then the design goal is met. We will just have to see how it does in extreme weathers.
    The lifetime MPG in the screenshots range from 50.5 to 71.5 MPG. The fans seem to be ignoring them.
  6. austingreen
    austingreen Senior Member
    13,574
    4,114
    Austin, TX, USA
    Video: Chevy Volt Does 0 to 60 in 8.53 seconds, Gets Over 40 Miles EV Range and Under 30 MPG in CS Mode
    comments indicate the expectations now are for a faster 0-60 time when the production software is in place, but cs mode economy between 34-38 mpg. IMHO the 1.4L non di, non turbo, premium fuel using engine is giving even a worse performance than gm indicated when they chose it.
    http://gm-volt.com/2010/08/23/gm-ac...ons-for-next-generation-chevy-volt-generator/
  7. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    10miles may sound nice and good enough for anywhere, but then there are mountain passes where you need to go 70mph+ up a 8% grade then down, then up, then down, then up. Much more than 10miles at high speeds at high grades. Methinks the volt will need to crawl up the side with the tractor trailers after a couple hills.
  8. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    The thing that really bothers me is that GM is avoiding releasing any CS numbers and the launch date is quickly approaching. I'm happy for the Volt's release but I feel they are being a little deceiving with their numbers to their fans. Being honest to their customers and fans is a better approach.
  9. austingreen
    13,574
    4,114
    Austin, TX, USA
    I'm not sure where in America this is but can't imagine its much of a problem. IH are limited to 6% grade, and the car is set to have an 3.2kwh battery buffer in mountain mode. The car will recharge on the less steep parts and down slopes.
    This video may finally push GM to release a number. They have been saying around 40, admitting to 37 seems less risky than leaving the thought of 27mpg in CS mode out there.
  10. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    Actually watching the 'stopwatch' shows that while the divider was a ":" the right-most digits were going from 00-99, so 8.53 seconds is correct. And in my timing along with the video it seems like 8.something is accurate.
  11. hill
    8,183
    It may very well be ... eventually ... if/when it hits the sales room ... but how can you really say it's a great car when:
    1) There are none yet
    2) Only GM people (which are NOT world famous for truthfulness), and their hand picked test subjects have driven the prototypes.
  12. austingreen
    13,574
    4,114
    Austin, TX, USA
    Hey I got to drive one, no restrictions on people if you were at the right place. But no want to really tell, since we were kept on a really small loop.
    I would say if you drive more than 15K miles a year the volt isn't for you. It's mainly economical only in 3 year lease for at 12K miles per year before a surcharge. I drive about 13K miles per year and would use only about 3K miles a year in that over 40 mile range. That would only be 100 gallons of gas at 30mpg, likely less. But I have a less than 1 year old prius and gm needs to prove quality. There is definitely a market out there, especially if they get price down, fix the inevitable bugs, and change out that poor engine. Remember they were estimating prius efficiency CS mode with a 1 liter di turbo flex fuel ice. GM doesn't appear to be willing or able to build this beast but there are at least 4 similar engines available next year from other manufacturers, and none of them need premium gas.
    The biggest impact from the volt might be to get other car makers of the pot and build other plug ins that we want.
  13. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Rocky Mountain passes over I-70 are the ones I come into most. Yes interstates are limited to 6%, however you can get waivers today to go above that limit. Also this was the first interstate built through the mountains when there was no such limit and as such goes to 8%+. There is little that can be done to limit grades when passing through gigantic mountains other than take the Japanese approach and literally tunnel straight through everyone of them.
    8kwh is nice, but at those speeds uphill it will be gone fast. This seems like the worst case scenario I could picture myself in if I were to ever buy a Volt.
    There will not be much time for recharging since you are going so fast. You have less than a minute of recharge for another battery taxing steep grade uphill climb at high speeds. Essentially it is miles after miles of steep uphill with breaks every few minutes for a very limited time.
    Sort of like SOC: 100%, 90%, 91%, 81%, 82%, 72%, 73%, 63%... You regain some (i.e. 1%) but you expend more (i.e. 10%). Note the numbers were pulled out the air for example :)
    So I guess we need to know what sort of kwh/mile uphill it needs and its maximum CS charge rate to figure out if it will strand you on the side of a mountain.
  14. ksstathead
    ksstathead Active Member
    1,244
    243
    Kansas
    My guess: no stranding, but somewhat limited climb rate in the Rockies. I also wonder what such driving will do to pack life if done regularly.
  15. austingreen
    13,574
    4,114
    Austin, TX, USA
    sorry, bad math on my part, the buffer is 3.2 kwh (20%*16kwh), somehow I multiplied by 40. If we take the weight to be 2000 kg then this is enough power to lift the vehicle about 1800 feet (3200wh*3600sec/hour/9.8m/s/s/2000kg). add in what ever std climb you get from full engine hp at speed and you will get the point that the car needs to slow down.
  16. john1701a
    12,755
    5,245
    57
    Nope, it's still wrong!
    I downloaded a copy of the video, all 130 MB of it, then marked the file with precise begin & end. I did it by viewing the video frame-by-frame with Pinnacle Studio. That measured an index from when he tromped his foot down to when he said 60.
    The software noted time came to 10.22 seconds.
  17. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    That is like Prius, maybe slower.
    The Volt would feel like a V6 from 0-30 mph but above 60 mph will feel sluggish. 62-79 mph acceleration is 3 seconds slower than Prius.
  18. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    Driving the Prius ?
  19. SageBrush
    11,627
    2,530
    Southwest Colorado
    The generator pushes about 53 kw sustained maximum. If 15 kw is used for everything but the climb, then 38 kw can pull the car up at a rate of
    mgh/sec = 38000 watts, or 2.15 meters/second for a 1800 kg car. An 8% grade implies (I think) 12.5 meters distance for 1 meter height, or 60 mph
    However ... braking and passing would have to come out of the battery buffer. Some degree of restraint would be smart, which may or may not be a feature of the driver.
  20. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Yup. The past few times have been in my GenII. No problems maintaining speeds of 75mph+. Only trouble is when you get cutoff and then have to accelerate to speed up those grades. Maintaining is no problem, accelerating can be hard after 65mph or so.
    Battery SOC drops to 40% (1bar) within minutes of getting to the area, then regen kicks it back up then down again and so on.
