Chevy Volt will have 'mountian mode' to store extra power
Discussion in 'Chevrolet Volt' started by hampdenwireless, May 4, 2010.
  1. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    GM Chevy Volt to feature 'Mountain' mode | Green Tech - CNET News
    Answering the question about if the ICE can charge the batteries.
    This mode would not be needed often, and even without it the car would still be able to climb the steepest mountains in America with normal roads.
  2. john1701a
    john1701a Prius Guru
    12,755
    5,245
    57
    We always knew the ICE would charge the battery-pack. That's how it maintains the regular 30% minimum. Adjusting it to offer a greater buffer is just a software tweak, adding a button on an option screen.
    The mode that will be needed often is for the heater... all winter long here.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,997
    Fort Lee, NJ
    Having to select a mode to fit the terrain will be confusing to the driver.
  4. djasonw
    djasonw Active Member
    950
    116
    Coconut Creek, FL
    Owning the vehicle will be confusing to most people!!!!
  5. Tideland Prius
    16,155
    But not any different than the terrain selector on Land Rover vehicles.
  6. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Also heard it will have Eco and Power modes to adjust pedal sensitivity, hmmm...
  7. hampdenwireless
    1,104
    86
    Baltimore MD
    Selecting the mode is completely optional. I think if you run into a huge mountain regularly you will love the feature and know when to use it.
  8. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I have a perfectly good "terrain selector" under my right foot
    in the prius, how is this different?
    _H*
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It tells the system to force charge the HV battery to the high limit. That way you have more charge in the battery before starting the hill.
    Tom
  10. hampdenwireless
    1,104
    86
    Baltimore MD
    While the Prius and the Volt are quite different they both have one thing in common:
    They have a peak HP output that is higher then their sustained HP output. Take a Prius (gen3) up a steep hill and at first you have 134HP but once the battery is exhausted you have 98hp, with the Volt its worse, you start with 149hp and end up with 71hp. Both cars will climb the biggest mountains in the USA (with proper roads) with no problem at reasonable speeds with the lower HP numbers. What the mountain mode does is allows you to store extra power so you have 149hp for a longer period.
    3x a year when I drive through the Pennsylvania mountains I would use this mode (if I had a Volt!).
  11. usbseawolf2000
    14,487
    2,997
    Fort Lee, NJ
    I think they would raise the minimal SOC a bit higher as they said the EV range will be lower. The ICE should also run near WOT most of the time to conserve the remaining battery charge.
  12. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    The more I read about the Volt, the more I find myself doubting the design, and anxiously awaiting the on-road driving experiences of the public. At first, I assumed the "Mountain Mode" was similiar to "Power" mode on the Prrius. Now I have my doubts.
    I read elswhere on PC the ICE is the Prius is retarded when it first starts to better control emissions, and power is reduced. In time, emission components are warm, and the ICE becomes more efficient.
    Now consider the Volt. We live 30 miles from a long steep mountain pass. So the Volt departs home, runs in EV mode for 30-35 miles, then comes to the grade. The battery is depeleted, the ICE is stone cold, and when needed for the grade, it must go through the emission controls warm up ... I assume at lower power and efficiency.
    It will be interesting.
    One additional thought. I was looking at the Tesla S online. Impressive. Mention is made that provisions have been made to easily remove the battery pack. Has anyone any idea how the battery pack in the Volt will be removed? That large "T" shaped battery would appear to be problematic to replace.
  13. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    In mountain mode, you will got ~25 miles in EV mode before the ICE will kick in to go into CSM because the SOC will be kept at 40-50% instead of 30%. That means the overall mpg will be lower.
  14. bisco
    49,489
    yes, they are quite different. the prius is a real car. the volt? an idea we can all make claims about without any proof in reality.
    great discussion tho!:cool:
  15. qbee42
    18,058
    3,074
    Northern Michigan
    We don't use that term on PC. We say the ICE is challenged.
    :D
    Tom
  16. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    I can see the commercials now:
    "Hi! I'm a Volt!" (played by a loud overweight guy in his late 50s with an obviously fake toupee, plaid jacket, lime green pants, and white shoes, puffing on a cheap cigar).
    "And I'm a Prius." (Played by Ira Glass)
