CHG mode to increase overall range
Discussion in 'Prime Main Forum (2017-2022)' started by Dave7, Jun 17, 2020.
  1. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    (Reposted as a new thread).To me the big advantage of CHG mode is to increase overall range. Right before stopping to fill the gas tank run the CHG mode, then with the added EV miles you have almost maximum range. Almost full battery and full tank. Good for long trips.I don't know how much fuel it takes in CHG mode to charge the battery so if you are running real low on gas this might not be the best idea.
  2. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    It would be an interesting experiment to see how much fuel is used for a given amount of charging. Has anyone tested it?
  3. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    Gas-only range is 500+ miles.
    30 miles of EV don't make that much difference.
  4. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Looking at a Gal/hr calculation the amount used will be determined by the battery SOC at the time. The more drained the battery is, the more load on the ICE. On the highway it might not make a big difference when the ICE is running anyway. In town the ICE can be pretty well loaded if the battery is drained. (compared to normal ICE fuel use). You can do your own calculation just by calculating the fuel used by the total miles driven while charging then running EV till drained again. I'd be pretty surprised if you came out ahead.
  5. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    You are charging the battery using gasoline. Yes, the range would be longer by the amount of 80% charge at the time you fill-up the tank on a road, but you reduced the range on the tank before the fill-up. My feeling is that the reduction in miles you might have been able to drive before filling up is greater than the EV range from the 80% charged traction battery using CHG mode. That is, the overall range would be shorter if you use CHG mode than not use it.
    jerrymildred and Hicksite like this.
  6. GSK
    GSK Active Member
    169
    107
    Baltimore, MD
    to me it's worth it just to be able drive more in EV mode.
  7. eatriceyo
    eatriceyo Member
    45
    33
    Honolulu
    why waste gasoline when you can charge for free at certain charging stations.
  8. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    Can't charge for free while driving. My time isn't free, and it's rarely worth it to wait at a charging station.
  9. bisco
    52,380
    if you get 20 miles of ev, will you lose any hv?
  10. Wolfie52
    Wolfie52 Senior "Jr" Member
    143
    124
    No. Carolina
    I see people doing this all the time. Usually they drive Leafs.
  11. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    no, you run in charge mode until you get to the gas station, then you fill it up and have a full tank and battery
  12. Salamander_King
    11,024
    8,970
    New England
    But you lost HV range on the tank before by lowering mpg with CHG mode. Thus the overall range is shorter.
  13. Dave7
    Dave7 Junior Member
    45
    CT
    2020 Prius Prime
    ok, I see what you mean, guess we would need to find a gas station on the bottom of a hill.
    Salamander_King likes this.
  14. Schrauger
    Schrauger Junior Member
    27
    You might get more range in the sense that you can run the gas tank empty. Either when charging or afterwards, if you keep it on gas mode until the tank is dry, then use the tiny bit of electric to get to a gas station. That will get you the maximum range possible, rather than filling up the tank when you still have a gallon or so left.
    With a fully charged ev battery, you lose range anxiety on the gas side. Once you use up the last drop of gas and start going to electric, you know how many miles you have to find a gas station before you're dead in the water. Assuming you're not out in the boonies, 20-25 miles is plenty to find a station to fill up the tank from empty to full.
    But if you don't run it dry, then I don't see how it would help you. You'd have a longer second leg, but your first leg would be reduced because of the gas used to charge the battery. Combined with the conversion loss, I don't think your overall trip average would have fewer stops for fillups.
  15. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    I remember something about running a tank dry is bad for the Prius.
  16. Trollbait
    12,678
    Running the tank dry in any car risks damaging the fuel pump from overheating.
    In regards to non-plug hybrids, people have continued driving with an empty tank, which overdraws the battery, damaging it.
    Blair McCall likes this.
  17. Blair McCall
    Blair McCall New Member
    2020 Prius Prime
    It depends on a lot of factors. You will operate less efficiently in charge mode. As power from the motor is transferred to the battery there will be losses.
    The most efficient method to charge is obviously by plugging it in - assuming electric rates are reasonable. There are some cases where charging electrically will cost more than the increase in gas.
    I am a new Prime owner and I am still working on figuring out what works best for me. So far, running charge mode on the highway to top off my battery and using EV mode on the surface streets has yielded the best results.
  18. Mikhail Bond
    Mikhail Bond Member
    138
    66
    Socal
    I only get 430
  19. Salamander_King
    11,024
    8,970
    New England
    Do you drive fast? Or do you do a lot of short trips on HV? DTE is roughly the reflection of the mpg on your last tank. Gas empty light comes on after using ~9.3gal from a full tank. It changes quite bit if your driving condition changes. In my case summer best DTE is upper 500s miles, but in wither it drops to upper 400s miles. For 430miles DTE, your last tank mpg was 430/9.3=46mpg which is bit low, but not unreasonable. My mpg drops to 40s in winter, but goes up to near 60 in summer.
    See this thread: What is your DTE after fill-up? | Page 2 | PriusChat
    #19 Salamander_King, Jul 2, 2020
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    The advertised range of the tank is calculated by multiplying the EPA estimated mpg by the amount of fuel in the tank. Going that far (assuming the EPA mpg) would mean running it till it's completely out of gas. So, the advertisements for 540 miles total range are very unrealistic unless you're getting well over EPA mpg and willing to drive with the gauge on empty for a long time. Not the way most drivers operate.
    Trollbait likes this.
