Chilly Bay Area nights and an engine rattle at starts
Discussion in 'Gen 3 Prius Main Forum' started by Rxgolfer, Feb 21, 2018.
  1. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    Hey guys I think I may have the same issue about the noncurable but harmless engine rattle with chilly weather starts. But I’m not sure and I would like your opninon.
    So my 2010 Toyota Prius with 200k miles and never had any problems whatsoever before 3 days ago started rattling for a few seconds when I would turn the power on. The check engine light is on. It’s a bit chilly in the Bay Area at the moment.
    I Took the car to a mechanic and engine codes P0301, P0302 was what came up on the scan gauge. He replaced spark plugs, coils, engine oil, replaced valve cover gasket, oil pressure sender. All in all $1000. He did a full inspection and didn’t find anything wrong otherwise afterwards,drives well, engine is still strong.
    I head home and it’s now 7 pm chilly again and my car rattled again and it’s displaying the check engine light again. Is it something serious? Or is this the noncurable chilly weather rattle? I’m worried and thinking about selling the car now.
  2. JC91006
    16,475
    8,393
    It's unfortunate you spent $1000 on this car, you may have a bad head gasket. Probably best to sell it or you'll be needing a new engine soon
  3. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    I probably spent $1000 on nothing huh? Will the check engine light go away after a while?
  4. JC91006
    16,475
    8,393
    It's probably still misfiring, same problem from before the $1000.
    You can try cleaning the egr circuit but your car is already at 200k, sell it now while it still has a little value. Adding more miles won't help you
    You can disconnect the 12v battery for a minute to get rid of the check engine light temporarily or erase it with a code reader
    #4 JC91006, Feb 21, 2018
    m.wynn likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    You the diy type? Have your own scanner? Just done the by the book maintenance? How stable is your engine coolant level? Burn any oil?
    Keep us posted (y).
    #5 Raytheeagle, Feb 21, 2018
    m.wynn, SFO and JC91006 like this.
  6. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    I dont have my own scanner but..I am off tomorrow. I've done my own oil changes and spark plugs before but I'm not a pro by any means. And yes, i'm good about maintenance. How do I check stability of coolant oil/ oil burn
    Could it possibly be this?
    2010 Rattling in engine bay on start up? | Page 2 | PriusChat
    My engine sounds just like this:
    m.wynn likes this.
  7. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    Intake manifold needs to be cleaned of the oil being sucked in.
    m.wynn, JC91006 and Raytheeagle like this.
  8. JC91006
    16,475
    8,393
    It's sad to read so many turd gen cars dying an early death, many cases before 200k miles
    Grit and m.wynn like this.
  9. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Ever clean your egr circuit? What about pull the intake manifold and see if the ports are clear on the egr return?
    Where in Walnut Creek are you located?
    I have to meet another member to do some equipment drop off, which includes Techstream ;).
    You got a place to work? If so, we could probably help you out :).
    Keep us posted (y).
    Grit, PosauneGuy, m.wynn and 2 others like this.
  10. JC91006
    16,475
    8,393
    If the head gasket is bad, not much can be done now with cleaning egr and intake manifold
    m.wynn, m3pare, SFO and 1 other person like this.
  11. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    I'd love to meet or drive anywhere! I'm actually in fremont now. I have never cleaned th egr circuit or pulled the intake manifold.
    m.wynn, SFO and Raytheeagle like this.
  12. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    What do you think is the root cause?
  13. JC91006
    16,475
    8,393
    Clogged EGR circuit and oil in the intake manifold
    PosauneGuy, m.wynn, SFO and 1 other person like this.
  14. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    Living in Fremont, or just there at this moment in time? If you’re in Walnut Creek tomorrow, if could probably help you out.
    If not, we have a meetup in Lafayette next weekend where we could do some investigating:
    Possible Monthly install meets. Bay Area-Fremont
    Let us know(y).
    m.wynn, SFO and Rxgolfer like this.
  15. JC91006
    16,475
    8,393
    Ray on vacation? It's Thursday tomorrow
  16. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    After 5;).
    I’ve got mouths to feed:whistle:.
    But I’m meeting @SFO to drop off the Prolong equipment and Techstream after work. So the location can be flexible(y).
  17. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    i'm living in fremont right now. I'm totally willing to drive to Walnut Creek. I have no tools but willing to purchase all the tools necessary.
  18. padroo
    padroo Senior Member
    2,763
    2,250
    Sounds like your mechanic turned on what is referred to as the "Part Cannon".
    They fire a lot of parts at the car hoping they fix something.
    Seriously it needs to be properly diagnosed before repairs are done.
    audiodave, pilotgrrl and jerrymildred like this.
  19. Rxgolfer
    Rxgolfer Member
    56
    29
    Walnut Creek, CA
    I know I should have just told him not to start anything and to get a second opinion first...
    m.wynn and Raytheeagle like this.
  20. JC91006
    16,475
    8,393
    After 5 on a chilly day, maybe best to do this on a weekend meet up
    Raytheeagle likes this.
