China Syndrome in Japan?
Discussion in 'Fred's House of Pancakes' started by SPEEDEAMON, Mar 12, 2011.
  1. SPEEDEAMON
    SPEEDEAMON Professional Car Nut
    1,556
    606
    Los Angeles
    There's a lot happening at the Nuclear reactors in Fukushima.
    Cooling problems, stuck vent relief valves, exposed and melting rods, cessium leakage detection, explosions and white smoke as of 16:00 local time.
    This could be a start of the China Syndrome because already 10 kilometers diameter has been evacuated.There's a lot that they aren't saying which scares me.
    But since the opposite side of Japan on the planet isn't China, what would be the proper name for this syndrome?
    The explosion blew the walls off of Reactor #1.
  2. uart
    uart Senior Member
    4,215
    1,200
    Australia
    Yeah it looks like it's starting to get more serious. Here's the latest report from out local news :
  3. DavidA
    2,328
    1,812
    Chicago western burbs
    There's no power. How could they turn on their air conditioners?
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Surely there must be a nuclear expert or knowledgeable person on this forum who could explain simply what is happening to the plant and what could happen.
    Obviously the core doesn't melt right through to the other side of the world but how deep does it go? Does it keep on working its way deep into the earth? Would this cause it to explode?
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    FYI,
    Following is a copy of my post.
    JP government spokesman announced it was hydrogen explosion made from leaked steam.
    The explosion occurred out of the reactor container within the building.
    The reactor container itself has no damage, and the radiation level is not increased since then.
    Keep in touch for further announcement.
    Ken@Japan
    2 people like this.
  6. Skoorbmax
    Skoorbmax Senior Member
    2,641
    264
    Western NY
    A lot they aren't saying because I'm pretty sure at this point a lot they don't know. When in doubt just evacuate seems to be a prudent measure and one they're taking.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The explosion was from a pump, not the nuclear reactor. There have been many explosions following the earthquake, so this is not unusual. Look at all of the burning building for a good example.
    The collapsed roof is not related to the explosion. It is the roof of the containment building, not the the containment vessel. The containment vessel is the hardened structure which actually houses the reactor. The containment building is just a normal building around the containment vessel. It serves only to protect the equipment and workers from weather and is in no way related to containing the nuclear material.
    The release of some nuclear material, which was referred to above as a "stuck valve", is in fact a pressure release which vents excess pressure from inside of the containment vessel. Excess heat creates steam, and this pressurizes the reactor. The amount of release radiation is minimal.
    Normally, when a reactor is shut down, control rods slide down into the reactor and slow the reaction to a very low level. In this essentially powered-off state there is very little heat generation, so little cooling is required. What we don't know, since our news services supply very little real news, is how the reactor was shut down. If the rods are in place it shouldn't be a big deal. If not, there will be scrambling to keep things cool and get the reaction moderated.
    Tom
  8. Flying White Dutchman
    4,374
    313
    "ïf the rods are in place it shouldn't be a big deal. If not, there will be scrambling to keep things cool and get the reaction moderated."
    so it seems that things heat up to keep it cool.
  9. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    You can get live streaming using the iPhone app NHK World TV Live for live videos and latest updates not shown here.
  10. fuzzy1
    10,159
    After the main power producing chain reaction is shut down, there is still considerable thermal power from short life decay products. The emergency cooling system needs to run for several weeks.
    SciAm (How to Cool a Nuclear Reactor) doesn't have much content yet, but NPR (Explosion at Japanese nuclear plant) has a running blog.
    The Wikipedia page for this plant is
    [ame="http://en.wikipedia.org/wiki/Fukushima_I_Nuclear_Power_Plant"]Fukushima I Nuclear Power Plant[/ame], and is changing rapidly. This is a very old plant, and was apparently within a couple weeks of planned retirement.
  11. amm0bob
    amm0bob Permanently Junior...
    7,730
    2,547
    It doesn't look good...
  12. SPEEDEAMON
    1,556
    606
    Los Angeles
    The real scare is what they are not saying and holding back.
    The Japanese authorities always downplay disasters so as not to induce panic. Throughout the press conferences they emphasize calm and composure on their citizens and evacuate without panic. However when radiation is leaking out at catastrophic levels, you better get the hell out quick. What happened to the other reactors? What damage did they suffer or what they are doing inside to fix it and what's being covered up. The radiation levels could have been high as early as right after the quake and many have already been exposed.
  13. fuzzy1
    10,159
    Another source claims that this incident is currently a 4 on the [ame="http://en.wikipedia.org/wiki/International_Nuclear_Event_Scale"]International Nuclear Event Scale[/ame].
    For comparison, Chernobyl topped the scale at 7, and another Soviet disaster was the only 6. Three Mile Island was a 5, as were Windscale, Chalk River, and the Brazilian scavenging incident of a medical cesium radiation source. The link above lists numerous other 4s.
  14. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Here's a recent article saying the evacuation circle has been expanded to 20km. The metal containment shield is still in place, but pressure is building, and the reactor is not being sufficiently cooled. Not to be an alarmist, but the worst case scenario involves explosion of radioactive material, and radiation blowing across the Pacific.
  15. qbee42
    18,058
    3,074
    Northern Michigan
    I wouldn't worry about it, unless you live on the west coast.
    :p
    Tom
  16. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    This looks pretty bad. The plants are Boiling water reactors. This means that when they lose cooling, it's because they have lost water altogether. The explosion was from hydrogen coming from the core....and it looks like a lot of hydrogen was generated and exploded. The mentioning of "seawater" being used for cooling sounds like fire pumps spraying water onto or into the vessel. That has to be a really bad situation.
  17. tpfun
    tpfun New Member
    791
    Oh Never Mind,CA
    The second reactor is now partially melting down.
    The rest are increasing in pressure and requires release of radioactive steam....
    Not looking good.
  18. mojo
    mojo Senior Member
    4,519
    390
    San Francisco
    Whoops.The global warming doomers plan is to replace fossil fuel with nuke plants.
    Just a dumb plan.
  19. amm0bob
    7,730
    2,547
    If they are replacing them with the WRONG KIND OF NUCLEAR PLANT then I would agree...
    Thorium based nuclear generation plants are a viable alternative... and safer.
  20. amm0bob
    7,730
    2,547
